Accessory suggestions for first table saw
Forum topic by pj1 posted 03-01-2013 09:19 AM 2327 views 0 times favorited 38 replies Add to Favorites Watch
View pj1's profile
pj1
9 posts in 1985 days
03-01-2013 09:19 AM
Topic tags/keywords: question r4512 tablesaw tablesaw accessories
So, I finally pulled the trigger and bought my first table saw. Due to budget and space I decided on the ridgid r4512. Unfortunately the HD in my area shot down my harbor freight coupon. I tried hemming and hawing my way to a discount vut apparently my negotiation skills are about as good as my woodworking skills and got no discount. I will begin tackling set-up tomorrow but it may take awhile due to now having a 2 week old in the house. My question is what you guys have found to be the most useful accessories. I am already thinking of purchasing the incra miter gauge, zero clearence insert and dado insert. Oh and a new blade of course. I guess a gauge to set alignment is necessary. Already I can see the dollars adding up. I would appreciate any suggestions and tips you more experienced jocks have learned along the way! Hope to finally get a project on here soon
Thanks!
38 replies so far
View jeff's profile
jeff
1083 posts in 3516 days
#1 posted 03-01-2013 09:59 AM
For my Rigid 4512 I purchased a Freud D10-50x thin kerf blade and a Freud D10-80x cross cut blade and I’m happy with both.For a dado blade I purchased the Delta 7670 which produces pretty good flat bottoms and comes in a nice case.Then I added ZCI’s from Leecraft which really helped in producing cleaner cuts.You have to make a table saw sled for added safety and repeated accuracy when combined with a stop block…And welcome to LJ’S…This is a great site with so much info and great people…
-- Jeff,Tucson,Az.
View knotscott's profile (online now)
knotscott
8078 posts in 3427 days
#2 posted 03-01-2013 10:54 AM
Congrats on the new babies (both)!
A good quality saw blade and accurate alignment are among the best things you can do to help the performance of your saw. Your saw should benefit from good 3/32” thin kerf blades. Tips for picking saw blades A good miter gauge and stiff inserts are also good suggestions….I’d avoid the cheaper inserts made from UHMW plastic, because they’ll flex…..steel, phenolic, ply, hardwood, etc., are better materials for inserts.
Safety devices like feather boards and push sticks are also good acquisitions. There are a couple of good table saw books that you might consider too….”Table Saw Magic” by Jim Tolpin, and Kelly Mehler’s table saw book.
View redryder's profile
redryder
2393 posts in 3153 days
#3 posted 03-01-2013 12:28 PM
This is a cool tool that I use often on the table saw…..........................
-- mike...............
View pj1's profile
pj1
#4 posted 03-01-2013 03:03 PM
I really appreciate all of the advice! I am heading out today to get some things like the blades, miter gauge, and inserts. I will check out that magnetic featherboard also, thanks mike. Jeff, I am going to scour lumber jocks here for a solid table saw sled design. I will definitely be picking up that book. It seems there is really no way around laying down over half the cost of the saw on accessories. Looks like I will be sneaking these into the basement
View Francisco Luna's profile
Francisco Luna
943 posts in 3445 days
#5 posted 03-01-2013 03:07 PM
dear lumberjocker…...keep yourself humble enogh for sometime to learn about using the machine, there is not need of anything for now…..spending money and getting gadjets are not going to make you a better woodworker, maybe just improving your negotiation skills.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View History's profile
History
399 posts in 2033 days
#6 posted 03-01-2013 03:10 PM
Forget the fancy miter gauges, they are a waste of money in my opinion, and sleds can be dangerous. I say buy or build an outfeed table.
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2016 days
#7 posted 03-01-2013 03:22 PM
An accurate miter gauge is one of the best investments for a table saw. They make precise and repeatable crosscuts easy. Coupled with well tuned crosscut sleds, your new saw will allow you to build some great projects. Keep reading about the different sled designs. I have several sleds that I use for miters, bevels, and squaring panels. They really expand the capabilities of the saw.
Instead of wasting money on an outfeed table, get an adjustable roller.
-- Artisan Woodworks of Texas.... www.awwtx.com
History
#8 posted 03-01-2013 03:37 PM
I do not know of any professional trim carpenters that do the majority of their crosscuts with a table saw. Adjustable rollers stands are ok, but an outfeed table is far better.
View ChrisK's profile
ChrisK
1979 posts in 3133 days
#9 posted 03-01-2013 03:48 PM
An out feed table will triple the usefulness of the saw. I did buy an extension for my miter gauge to help hold longer pieces and to make it easier to mount a back up board to get rid of tear out. I do not use a full sled, instead I made a sled to hold panels. The best accessory I purchased for my table saw was a 12” sliding compound miter saw. I do almost all of crosscuts on it. For longer pieces it is the safest way to go. I still use the table saw to make dado’s in a crosscut fashion, though I am using my router for more of that work.
Other than the above a thin kerf rip blade, good stacked 8” dado set and good feather boards.
(I know the CSR saw is not a real table saw accessory but I sure use at as one. I am sorry I waited so long to buy one, damn budgets.)
-- Chris K
SamuraiSaw
#10 posted 03-01-2013 04:20 PM
”I do not know of any professional trim carpenters that do the majority of their crosscuts with a table saw.”
Umm, I don’t either Chuckie. What’s that got to do with this topic?
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3210 days
#11 posted 03-01-2013 04:31 PM
@Sawsucker – Professional trim carpenters use caulk…for a reason.
-- jay, www.allaboutastro.com
View moke's profile
moke
1186 posts in 2828 days
#12 posted 03-01-2013 04:41 PM
Wixey angle readout…
I check my angle of the blade constantly. You have stops for the zeroing the blade in your arbor assembly, but saw dust can build up and make it inacurrate. It takes 15 seconds to check it and it may save you some day. They are not much, there are two models, I got mine before the “fancy one” came out and it is just perfect. It uses a watch battery, stop at a battery place and oick up a two pack, just in case you forget to turn it off! Don’t ask me how I know this….
Buy a big pack of pencils and a cheap eletric sharpener, and keep a good point on them fro accuracy and put them EVERYWHERE in your shop.
Have fun wioth your new saw….
-- Mike
SamuraiSaw
#13 posted 03-01-2013 05:28 PM
+1 on the Wixey. I use mine daily!
View DaveJinMA's profile
DaveJinMA
2 posts in 1975 days
#14 posted 03-01-2013 05:47 PM
Congrats on the new baby. The human one that is. I;m in almost the same situation. Ours is 8-weeks old today. Still deciding on the table saw though.
I’ll echo what’s been said above, an outfeed table and a good blade.
View darthford's profile
darthford
611 posts in 1975 days
#15 posted 03-01-2013 05:58 PM
Starrett combination square and Incra Miter5000 crosscut sled.
showing 1 through 15 of 38 replies
