Moisture Meters
Forum topic by bbqking posted 72 days ago 163 views 0 times favorited 5 replies Add to Favorites
View bbqking's profile (online now)
bbqking
276 posts in 260 days
72 days ago
I have finally found a sawmill down below Atlanta with great prices on custom cut hardwood lumber. This is air dried lumber and I want to get a handle on moisture content. This is a new one for me. I want to be sure that moisture is at least close to 6-8% before I have it sawed and take it home. I need help on choosing and purchasing a moisture meter. Any one out there with some advice?
-- bbqKing, Lawrenceville
2081 posts in 558 days
72 days ago
I don’t believe you will get any wood ( air dried) that reads 6-8% water content.
You should probably be looking at 10-12% when you mill it and a further reduction when you store it indoors.
Try Lee Valley for a decent meter..
Cheers
13523 posts in 937 days
72 days ago
I have a Ligomat pin meter and a Wagner pinless meter. The Wagner has gone missing about 3 years ago and I haven’t found it. That’s why I bought the Ligomat.
They are both good meters.
bbqking
72 days ago
The sawmill owner says it is at 10%. I would like to verify that. What do you guys think is a good number?
View SawDustnSplinters's profile
SawDustnSplinters
140 posts in 318 days
72 days ago
I use the Lignomat mini-Ligno DX it has worked well for three years now….you might find a used one on ebay or craigslist.org
http://www.lignomat.com/MoistureMeter/moisture_pin_meters.wood+nonwood.mini.DX.htm
Bob is right most air-dried lumber will be close to the EMC (equilibrium moisture content) for for wood outdoors and what region you are in. Around here it is between 12-13 %...even after you take 6-8% wood out of a kiln it will gain moisture to the EMC. So before and after you plane it, sticker it, put some weight on it and let it rest for a few days and equalize to the shop’s environment… For Atlanta, GA it is around 13.9% on average in September. It will vary from day to day and with the weather.. A good book to use as a reference is:
http://www.harvestingurbantimber.com/HUTbook.html
-- Frank, Little River/Academy, Texas , http://www.allthingsrustix.com
View socalwood's profile
socalwood
107 posts in 140 days
71 days ago
sawdustnsplinters is right
-- rob
Bookmark And Share This Page
