BS Blade for this cut?
Forum topic by cbehnke posted 02-28-2013 03:17 PM 794 views 0 times favorited 5 replies Add to Favorites Watch
View cbehnke's profile
cbehnke
89 posts in 2493 days
02-28-2013 03:17 PM
I’d like to get some feedback on good choices for a BS blade to do some curved cutting through hardwood up to 8/4 thickness, but here is the catch: i’d like for the blade to have no, or very minimal kerf, so it leaves the wood as smooth as possible so that I can do minimal clean-up sanding and piece it back together for a glue up with a tight joint.
I wasn’t able to post a pic of a project I did using that technique but it’s very similar to the cutting boards a lot of people refer to as “drunken” cutting boards
5 replies so far
Gerald Thompson
855 posts in 2111 days
#1 posted 02-28-2013 03:26 PM
Call Louis Iturra @ Iturra Design 904-642-2802. He knows all about BS. Ask him to send you a catalog. It is a great source if info.
-- Jerry
View MrRon's profile
MrRon
4575 posts in 3120 days
#2 posted 02-28-2013 06:25 PM
No such thing as “no kerf”. The narrowest kerf you can get with a saw blade would be using a scroll saw. The narrowest band saw blade, I believe is .020” thick. Cutting 8/4 hardwood would not be an easy task. Lots of broken blades.
View bondogaposis's profile
bondogaposis
4542 posts in 2228 days
#3 posted 02-28-2013 06:53 PM
There are no, “no kerf” blades. The width of the blade will be determined by the radius of the cuts you want to make. Use the widest blade you can get away with and still turn the radii that your project calls for. The finer tooth blades make a smoother cut but normally in 8/4 stock you want a coarse blade to minimize heat build up. You are going to have to find a compromise between tooth count and smoothness of cut.
-- Bondo Gaposis
View treaterryan's profile
treaterryan
109 posts in 2164 days
#4 posted 02-28-2013 06:56 PM
I think he is trying to say tooth set.
-- Ryan - Bethel Park, PA
cbehnke
#5 posted 02-28-2013 10:15 PM
right, thanks ron and bondo, i mis-used kerf. I was confusing it with the additional width of cut caused by the side to side blade tooth off-sets…which i now will call tooth set.
so i’m looking for zero to minimal tooth offset. learn more terminology every day.
