| Forum topic by FireFitzy | posted 80 days ago | 249 views | 0 times favorited | 8 replies | ![]() |
80 days ago |
Hey Everyone, Thanks -- Brian - www.dnrapparel.ca |
8 replies so far
#1 posted 80 days ago |
First… UNHOOK THE AIRLINE… then check for a jammed nail. -- Perform A Random Act Of Kindness Today ... Pay It Forward |
#2 posted 80 days ago |
No nail caught. I’ve fixed that issues a few times in the past. -- Brian - www.dnrapparel.ca |
#3 posted 80 days ago |
This would be simple and I’m sure you’ve checked it already but are you sure that you have enough nails in the gun? The nail guns I used at my old job had a built in trigger safety that wouldn’t fire a nail unless there was at least (say 5 or so) nails left on the clip..it would leak air near the trigger like you are describing. I would every once in a while wonder why it stopped working then realized I was getting close to the end of the clip so I would just add another and it would fire perfectly from then on. -- "Only put off until tomorrow what you are willing to die having left undone." -- Pablo Picasso |
#4 posted 80 days ago |
Most likely, the last nail you fired was the one that blew the gasket. Check to make sure the hammer isn’t stuck in the down position. If it is, pushing it back up might help. Your best bet is to look for a rebuild kit. They’re usually pretty inexpensive and pretty easy to install. -- Friends don't let friends use right tilt contractor saws...... |
#5 posted 80 days ago |
Right now I am not sure what a CH gun is but I have had this ecperience a couple of times. I have a Paslode framing nailer. It was working fine then sounded like it was leaking air. It was a gasket on the upper rim of the barrel or cylinder. Torn seal. It cost me about $7 at the local lumber yard to have all the O-rings and gaskets installed. Of course they treated me right because this is a town of 20,000 people and they want your business. The other times have been Porter Cable nailers. There is a white plastic or nylon part above the cylinder or barrel. The center will breaker out of this bumper. It is used to return the driver. IT seems to go out faster sitting that using. |
#6 posted 80 days ago |
CH = Campbell-Hausfield. -- Einstein: "The intuitive mind is a sacred gift, and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." I'm Poopiekat!! |
#7 posted 79 days ago |
Thanks everyone for the help, Grandpa seems to have had a similar issue. I’ll go that route and see what happens. -- Brian - www.dnrapparel.ca |
#8 posted 79 days ago |
I’ve torn down too many nail guns to mention. Sounds like an o-ring has torn and is not returning the drive piston back to the top. There are also some rings in the trigger plunger/valve (proper term?). If your somewhat mechanically inclined don’t be afraid to tear it down. Do it methodically and even take photos and make notes. As your pulling it apart check everything carefully for tears, cracks, excessive wear, etc. Watch out for any springs that may want to jump out at you and pay attention to the orientation of everything to get it back together properly. If you find the culprit look up your model # online and get a part no and check some sites for prices or better yet order it from a local yard or supplier. You can usually save on the shipping that way. -- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless. |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2737 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
