Is This a Good Deal on Drill Press?
Forum topic by tool_junkie posted 02-28-2013 06:24 AM 1833 views 0 times favorited 9 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
325 posts in 2525 days
02-28-2013 06:24 AM
All,
I need some help here. I have been wanting to buy a drill press for quite some time now. Last weekend I went to harbor freight and bought the following, but it is going back because it lacks power:
http://www.harborfreight.com/5-speed-bench-drill-press-60238.html
Today, the following showed up on the local Craigslist.
http://cedarrapids.craigslist.org/tls/3648716160.html
I want you guys’ opinion on it. What all should I check for before buying and how much to offer?
Thanks!
9 replies so far
View darthford's profile
darthford
601 posts in 1920 days
#1 posted 02-28-2013 07:33 AM
Hard to go wrong at $125, you could upgrade to a precision keyless Albrecht chuck and buy a new Baldor motor and your still only in to it $700.
View David Dean's profile
David Dean
608 posts in 2895 days
#2 posted 02-28-2013 11:35 AM
I would go with the craftsmen that 5 speed only has a 1/3 hp and they dont play well with oak and other hardwoods. I got one and it sucks.
View bbasiaga's profile
bbasiaga
1232 posts in 1991 days
#3 posted 02-28-2013 01:57 PM
I had one of those HF models forever. If you get used to it, it can do quite a bit. I used mine for years and finally wore it out on my telescope project when drilling stainless steel.
I upgraded to a Craftsman model not unlike that one. It is a different class of tool and should sever pretty well.
-Brian
View JoeinGa's profile
JoeinGa
7736 posts in 2002 days
#4 posted 02-28-2013 02:07 PM
125 bucks for a Craftsman floor model? How come you arent posting that you’re on your way to pick it up? :-)
View dhazelton's profile
dhazelton
2767 posts in 2292 days
#5 posted 02-28-2013 02:13 PM
With a good sharp bit and slow feed rate you would probably be okay with a bench top. But why bother? Get the floor model!!
View distrbd's profile
distrbd
2252 posts in 2442 days
#6 posted 02-28-2013 02:23 PM
I have one f those small drill presses similar to HF ,there’s no way to work around it’s limitations like narrow swing(distance from the chuck to the columnx2),short quill travel,low powered motor,and most of all ,limited speed range.
These limitations did not bother me at first(10 years ago) but as I needed wider pieces to drill or when I tried to use forstner bits which require lower speed, drilling stainless steel ,I realized I needed a bigger drill with larger capacity,but now I have to find a spot to store the old one in my very limited spaced garage or give it away .
So I think you save yourself now buy buying a HF drill press now but will regret not buying the bigger one from CL in the future.Buy the Craftsman.
-- Ken from Ontario, Canada
tool_junkie
#7 posted 02-28-2013 07:29 PM
I missed out… I was the 2nd person in line, but the first person bought it :(
View b2rtch's profile
b2rtch
4861 posts in 3044 days
#8 posted 02-28-2013 07:50 PM
I bought a HF floor drill press., 21 speed I believe but not sure, with 1/2HP motor for $100.00.
I am very happy with it.
HF has good drill presses.
-- Bert
View Woodknack's profile
Woodknack
11610 posts in 2376 days
#9 posted 02-28-2013 08:00 PM
Was the story of my life for months while searching for a drill press. I broke down and decided to buy a HF press and they were out of stock both times I went. Finally found a Jet/Orbit big benchtop model (3/4 the size of a free standing press) for $75 and couldn’t be happier. Dang thing weighs about 125 lbs. Moral is, good things come to those who wait. I found it by posting a wanted on a local woodworking website and even then it was about a month before one became available. Seems like there is a serious drill press shortage in my area.
