Another saw blade question.
Forum topic by Mark posted 02-28-2013 02:56 AM 642 views 0 times favorited 4 replies Add to Favorites Watch
View Mark's profile
Mark
900 posts in 1937 days
02-28-2013 02:56 AM
It’s been said that plywood has killed many a good router bit. What about table saw blades? I just bought a new 10” CMT GP blade. Should I get a cheep blade for plywood?
-- Mark
View DIYaholic's profile
DIYaholic
19596 posts in 2638 days
#1 posted 02-28-2013 02:58 AM
I don’t know if it’ll matter much, but that’s what I’m doing!
edit: I’m talking about construction grade ply for utilitarian projects. For cabinet grade ply I’ll use a good blade.
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#2 posted 02-28-2013 03:03 AM
I think you will want a good blade for the plywood. Good blade and a zero clearance insert in the table. You will get chip out or splintering of the veneer with most cheap blades.
View BBrown626's profile
BBrown626
37 posts in 1924 days
#3 posted 02-28-2013 04:24 AM
Get your best blade for sheet goods and keep it sharp. If you are using it on OSB or low grade ply for flooring then use a cheap general purpose blade.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2317 days
#4 posted 02-28-2013 04:28 AM
The cmt blades are good for plywood.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
