what sized lumber?
Forum topic by Chris P posted 02-28-2013 02:25 AM 1050 views 0 times favorited 12 replies Add to Favorites Watch
View Chris P's profile
Chris P
93 posts in 2527 days
02-28-2013 02:25 AM
Topic tags/keywords: bed dimensions lumber walnut
I’m about to build a queen sized bed using walnut, I have the design pretty much finished but I’m wondering what dimension lumber to use 4/4, 6/4 etc. I was thinking 6/4 for the legs and side/end rails would do the job. The side/end rails will be about 6 inches wide, could I get away 4/4 or should I go all the way to 8/4? Watcha think?
-- Chris, Long Island
12 replies so far
View Grandpa's profile
Grandpa
3261 posts in 2917 days
#1 posted 02-28-2013 02:31 AM
6/4 8 inches wide if I were building it. You will probably put in a 2×2 strip on the lower edge of the rail to support the slats. That will take away the lower 1-1/2” of the rail so it will not cover the entire spring. Just what I would do.
View ShaneA's profile (online now)
ShaneA
7064 posts in 2839 days
#2 posted 02-28-2013 02:34 AM
Anything above 1 1/8 or so would work. I used 3” square for the legs on my king sized bed build. May go a bit bigger if I were to do it again.
Chris P
#3 posted 02-28-2013 02:46 AM
The bed is based on this http://gingkofurniture.com/shop/lewis_bed/ http://gingkofurniture.com/shop/lewis_bed/ but the fabric headboard will be wood. I’m not planning on using a box spring I think making the rails 8” wide will make it a little bulky but some where in the middle of 6 and 8 might work to give it some strength.
ShaneA
#4 posted 02-28-2013 02:51 AM
Ahhh, given that design w/thinner rails, better get closer to 1 5/8 to 1 3/4. I agree, for this look 8” would be too wide. The legs may need to be still 2” maybe a bit more?
Grandpa
#5 posted 02-28-2013 02:52 AM
Well, I am thinking everyone is a big person and big people weigh more. If you aren’t large then why the large bed is my thinking. I would hate to build a bed that was not strong enough.
Chris P
#6 posted 02-28-2013 03:31 AM
Thanks Thanks for the input guys! Haha yeah we’re not large people I guess but we’re not small either Grandpa,but that’s definitely one of my main concerns, I want to build a bed that will stand the test of time.
Grandpa
#7 posted 02-28-2013 03:47 AM
take your tape to the store and measure a few.
View MNgary's profile
MNgary
303 posts in 2658 days
#8 posted 02-28-2013 03:57 AM
“take your tape to the store . . “
Grandpa has the best advice!
-- I dream of a world where a duck can cross the road and no one asks why.
Chris P
#9 posted 02-28-2013 04:09 AM
Ahhhh if it was only that simple, I’ve only seen this online, they only have stores in Californi , and I’m about an 8 hour plane ride away from there. That’s the only place I know that has it. :-(
Grandpa
#10 posted 02-28-2013 03:54 PM
Check a few beds locally and see what they used. Then you would have some real life direction on where you are headed.
View Loren's profile
10477 posts in 3889 days
#11 posted 02-28-2013 03:59 PM
Queen mattress is 60” wide. Print up the picture and
use measuring tools to figure it out.
I would use 5/4 for the sides because it’s
heavier visually. You can glue or screw another
cheaper board to the back of a rail to increase
stiffness.
You might want to look at the European wood
bed springs sold by IKEA. They are pretty cool.
Chris P
#12 posted 03-02-2013 05:14 AM
That’s actually what I ended up doing Loren, I measured know dimension on a picture of the bed with a piece of paper and from there was pretty much able to figure out the dimensions. I ended up getting 6/4 for the sides and 8/4 for the legs. We’ll see what happens, thanks all!
