Routing a spiral
Forum topic by Tokolosi posted 02-27-2013 08:39 PM 2598 views 0 times favorited 27 replies Add to Favorites Watch
View Tokolosi's profile
Tokolosi
678 posts in 2592 days
02-27-2013 08:39 PM
Topic tags/keywords: jig tip question trick router
I have an idea that would require me to cut a perfect spiral groove (1/2-inch deep and 1/2iinch wide) into a round, flat piece with a radius of 24-inches. I have been trying to figure out if it is possible to do with a router.
I think I can do it by placing a round tube or dowel at the center of the piece, attaching it to the router with a string and it would cut a spiral as its turned around the center tube as the string winds around the stationary tube. However, considering that half the diameter of the router base is about 4-inches, and added to the thickness of the center tube (say 2-inch diameter), the spiral (if this would actually work) would not continue to the complete center of the round piece.
Has anyone ever done something like this? Or know of a better way? or have a jig for it? Any input would be appreciated.
Ps. I do not have access to a lathe.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
27 replies so far
View DaddyZ's profile
DaddyZ
2475 posts in 3278 days
#1 posted 02-27-2013 08:43 PM
Check out a router crafter, for saleon ebay & other places as well
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 3094 days
#2 posted 02-27-2013 08:49 PM
I did it for a Labyrinth, I used rope worked great
cant see why the way your thinking wouldnt work.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Tokolosi
#3 posted 02-27-2013 08:51 PM
Thanks for the input DaddyZ. Thats a neat looking accessory.
However it appears that it is primarily designed to allow you to use a router to carve and cut round stock. I need to cut spiral in the top of a flat board. Im not sure it can be adapted to do that. But I will research it a bit more.
Jamie Speirs
#4 posted 02-27-2013 08:51 PM
If you remove the spring from a tape measure it will be more
precise than string.
jamie
Tokolosi
#5 posted 02-27-2013 08:55 PM
Thats good to hear Jamie, that its been done before. How tight of a radius were you able to get? and what was the diameter of the center post that you used? And were you able to get all the way to the center of the piece?
View Underdog's profile
Underdog
1248 posts in 2273 days
#6 posted 02-27-2013 08:58 PM
Send it to someone who can cut it on a CNC router. That’s the only way I can think of that will let you cut the spiral right to the center of the circle.
-- Jim, Georgia, USA
View JohnEinNJ's profile
JohnEinNJ
94 posts in 2585 days
#7 posted 02-27-2013 09:21 PM
What if you move the piece, rather than the router? I can’t quite visualize this, but what if you made a spiral-shaped “fence” out of 3/8 mdf, clamped it to the table so that when you start, the bit is in the center of the workpiece, and then rolled the workpiece along the mdf. Some variation on this should work – maybe someone with really good spatial visualization skills can comment.
Tokolosi
#8 posted 02-27-2013 09:32 PM
@Underdog: That may be the easiest (if not the cheapest) method. One I have already been investigating. I would love to do it myself though.
@JohneiNJ: Lol. I have a headache just trying to visualize that. But it is definitely an idea that bears further thought. Need to break out the pencil and paper I think before I blow an artery.
JohnEinNJ
#9 posted 02-27-2013 09:34 PM
Better solution: Make a spiral template and use a bushing in your router.
Tokolosi
#10 posted 02-27-2013 09:37 PM
Aha! Now you are cooking with gas! That is something I had not considered at all! HHhhmm. Gonna be some tight curves on a bandsaw but might be do-able.
This is why I love this site. Some incredible talent here. Thanks to all.
View Earlextech's profile
Earlextech
1162 posts in 2928 days
#11 posted 02-27-2013 09:42 PM
The tool to do it is called a Legacy as in www.legacywoodworking.com Check it out!
Tokolosi
#12 posted 02-27-2013 09:52 PM
That would be a nice addition to have. Alas I cannot afford such a tool.
View jaykaypur's profile
jaykaypur
4017 posts in 2646 days
#13 posted 02-27-2013 10:28 PM
Do as JohnEinNJ suggested and make a spiral formed template out of say….3/8’s inch copper tubing. That used with a bushing should be able to accomplish what you are trying to do. At least thats my 2 cents worth.
-- Use it up, Wear it out --------------- Make it do, Or do without!
View Hammerthumb's profile
Hammerthumb
2908 posts in 2213 days
#14 posted 02-27-2013 10:42 PM
Did you ever think of hand carving it?
-- Paul, Duvall, WA
Jamie Speirs
#15 posted 02-27-2013 11:00 PM
I left a 3” center as it was bigger and the lines were stopped.
I made a collar the same height as the center pole
