| Forum topic by fisherdoug09 | posted 85 days ago | 430 views | 1 time favorited | 6 replies | ![]() |
85 days ago |
Topic tags/keywords: copper lay work Here I go thinking again, hope I don’t hurt myself. Have any of you done any inlay work in copper as the inlay? I was thinking about using copper powder or granuales like I have used Turquoise. I am looking for a source if anyone can help. Thanks Doug |
#1 posted 85 days ago |
I’ve not worked with it but here is where you can get it. -- Bondo Gaposis |
#2 posted 85 days ago |
I don’t see where there would be any problem, other than the tarnishing. -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 85 days ago |
I’ve used copper strips for inlay and stringing several times. Nothing about copper is inherently toxic, so working with it isn’t dangerous. Properly sealed, copper will retain a bright finish. If you plan on a tarnished look, force the tarnish prior to applying the finish. -- Friends don't let friends use right tilt contractor saws...... |
#4 posted 85 days ago |
I’ve use copper powder in inlays. If it’s a tiny inlay, it’s much easier, but if it’s a large hole or check I fill it with black sand first using thin CA to hold it together, then I lay the copper dust on top of that and use thin CA. It dries in about an hour or two and when you sand the copper powder it then becomes copper. It won’t tarnish due to the CA acting as a sealer. The void in this bowl went all the way through, the main part of the inlay is black sand to give it body, then three coats of copper. As you can see, there are still some area’s where it could use more, but I like the texture this way. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#5 posted 85 days ago |
I’ve not used it either Doug but I am looking forward to seeing what you do with it! Thanks for sharing -- Chuck Emery, Michigan, |
#6 posted 84 days ago |
If you are looking for larger bits of copper (i.e., not powder) take a file to a bit of copper pipe and collect the filings. -- Mark Kornell, Kornell Wood Design |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
