How would I make these legs removable?
« back to Joinery forum
Forum topic by Scootles posted 02-27-2013 08:36 AM 4708 views 0 times favorited 24 replies Add to Favorites Watch
View Scootles's profile
Scootles
153 posts in 1824 days
02-27-2013 08:36 AM
Topic tags/keywords: joining modern
I’m looking to build this desk. I had it in the past, but an ex with a vengeance made quick work of it. I want to build it out of solid wood. Problem is, that I don’t know how I would fasten the legs AND have them be removable. When I had the desk, it was made out of MDF and it had those little Metal pegs that you place in the hole and tighten into the piece the slid into. As much as I hate MDF, they held the desk together EXTREMELY well while allowing me to remove them. Now I want to build this desk, and keep it movable because I foresee myself moving at least once in the next 2 years.
So, what do you guys think?
24 replies so far
View Purrmaster's profile
Purrmaster
915 posts in 2002 days
#1 posted 02-27-2013 08:45 AM
You could try pocket hole screws. As long as you don’t put glue on the joint you can simply put your drill in reverse and take out the pocket screws. Drive them back in when you’ve moved.
View HerbC's profile
HerbC
1721 posts in 2768 days
#2 posted 02-27-2013 03:58 PM
You could use the same type of fastner system the MDF desk used. Locally my big box stores carries all the standard hardware. It’s just a matter of careful design and execution. You have to get the right size holes in the right location and then it will work fine.
Have fun!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Mosquito's profile
Mosquito
9216 posts in 2201 days
#3 posted 02-27-2013 04:02 PM
I was thinking along the same lines as Herb, could get away with the same fasteners if you can find them.
If you want to go with out mechanical fasteners, you could always try using sliding dovetails from the back that stop just shy of the front. ;-) But you’d probably want tapered for that length.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View waho6o9's profile
waho6o9
8100 posts in 2486 days
#4 posted 02-27-2013 04:16 PM
Cam lock fasteners maybe?
View Lee Barker's profile
Lee Barker
2170 posts in 2759 days
#5 posted 02-27-2013 06:09 PM
The KD fasteners are fascinating and challenging and rewarding. No question about that.
An alternative to ponder is to feature, rather than hide, the fasteners. Think of ways they could become a design detail.
Alternatively, everything could be aligned with dowels and fastened inside with angle brackets.
Kindly,
View DKV's profile
DKV
3940 posts in 2413 days
#6 posted 02-27-2013 06:20 PM
Scoo, the reason you want removable legs is so you can hide it from the next ex?
-- This is a Troll Free zone.
Scootles
#7 posted 02-27-2013 06:23 PM
Partially lol.
I want them removable because I haven’t found a permanent home yet. I’m moving to Phoenix from New York in 2 weeks, and who knows what kind of moving around I’ll be doing out there. Someone suggested using these fasteners, and I think it may be my best option. What do you think?
View Clint Searl's profile
Clint Searl
1533 posts in 2270 days
#8 posted 02-27-2013 06:25 PM
Scootles
#9 posted 02-27-2013 06:26 PM
Clint, I’m afraid that image makes no sense to me at all.
View DKV's profile
DKV
#10 posted 02-27-2013 06:34 PM
Scoo, to keep it cheap I would use dowels. Glue the dowels to the tabletop but not to the corresponding holes in the three legs. The dowel end that fits into the legs could be tapered for a tight fit. I would then drill and countersink a hole through the sides of the legs and into the dowels. I would cover the screw heads with plugs. I would do the same thing at the two connecting points on the three legs (panels).
If you don’t want to keep it cheap then you could use any of the above suggestions.
View DS's profile
DS
2853 posts in 2329 days
#11 posted 02-27-2013 07:00 PM
Even though I am a fan of KD fittings, they are a bit more involved when you are manually cutting them as opposed to using CNC tooling.
Alternatively, you can use basic hardware like corner braces and mending plates. They can be mostly hidden up under the top and below the modesty panel.
View DKV's profile
DKV
#12 posted 02-27-2013 07:07 PM
DS, I really hate modesty panels…especially when I’m wearing shorts and want to show off my legs…
View MT_Stringer's profile
MT_Stringer
3154 posts in 3140 days
#13 posted 02-27-2013 07:26 PM
”DS, I really hate modesty panels…especially when I’m wearing shorts and want to show off my legs…”
Whew! TMI TMI :-)
MT_Stringer
#14 posted 02-27-2013 07:33 PM
@Scootles – here is some pretty good advice that might help prevent another desk demise. :-)
If you want to be happy for the rest of your life - Jimmy Soul
Edit Note: Listen all the way through. :-)
View sprucegum's profile
sprucegum
324 posts in 1906 days
#15 posted 02-27-2013 07:41 PM
I vote for the pocket screws and maybe a few dowels to help line things up. Drill a few extra pockets just in case some of them don’t hold well the second time around. Of course I often over simplify things I am a great believer in the KISS theory.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
