delta 34-670 blade stops cutting wood
Forum topic by brotherj posted 02-27-2013 08:34 AM 1455 views 0 times favorited 5 replies Add to Favorites Watch
View brotherj's profile
brotherj
3 posts in 2091 days
02-27-2013 08:34 AM
Topic tags/keywords: question
i have a delta 10 in table saw direct drive,motor roars bad weird,while cutting woood blade stops cutting motor still running.do i need a new motor??
5 replies so far
View Grandpa's profile
Grandpa
3261 posts in 2851 days
#1 posted 02-27-2013 05:36 PM
I doubt it. Sounds like the blade is loose or the drive is broken. Possibly a shaft that drives the blade but is inside the motor. Look into the exact cause. If it is inside the motor case there is possibly a repair part available from www.ereplacement.com They have a lot of parts and often videos on the proceedure to install the new part.
View MrUnix's profile
MrUnix
7005 posts in 2374 days
#2 posted 02-27-2013 05:55 PM
Pull the motor and take off the end cover to check the belt.. most likely stripped and needs replacement (yes, it does have a belt!!).
Cheers
brotherj
#3 posted 02-28-2013 04:12 PM
i thank you for your imput.if it was belt why would bade turn and cut feeding real slow,snail slow.when force to feed wood blade stops.noise as soon as turned on,weird loud noise.
MrUnix
#4 posted 02-28-2013 07:59 PM
It’s a cogged belt:
Eventually the ‘cogs’ get worn/ground/broken off and you experience what you describe. Pull the end cap off the motor and verify.
View Hugh1's profile
Hugh1
4 posts in 2077 days
#5 posted 03-12-2013 03:29 PM
Help guys, I think I have the same problem on the used D34-670 that I picked up. How do I get to the belt to inspect or replace it? Thanks.
Hugh
