| Forum topic by Bobmedic | posted 81 days ago | 668 views | 0 times favorited | 16 replies | ![]() |
81 days ago |
Topic tags/keywords: question This may seem like a stupid question but here it goes anyway. Does adding a chip separator increase suction in a dust collection system? I know dust collectors work off of an airflow concept rather than vacuum but adding a chip separator essentially creates a vacuum right? Maybe I’m wrong but I would like to hear why. -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
16 replies so far
#1 posted 81 days ago |
You can’t say a dust collector doesn’t work on vacuum. It does. Simply put, a dust collector system is a fan sucking air from a dust source and either pulling it through, or blowing it into, a filter of some sort. Some systems do both, they pull dust laden air through a cyclone separator and then blow it into a bag or cartridge filter. these are called Two stage collectors. But in either type system, the fan is the component that creates the vacuum that moves the air. The movement of air is measured by volume (CFM cubic feet per minute) and velocity (FPS feet per second). A shop vac is an example of a collector that moves a small volume of air but can move it at very high velocity. It takes high vacuum pressure to generate the high velocity and that is what shop vacs do best.. These are good collectors for capturing dust that is moving very fast, like chips coming off a router or a small contained area like a Random orbital sander. These tools may have small 1 1/4” hose connections so it takes a lot of vacuum pressure to suck the air through those small hoses. Many shop vacs pull around 100 CFM but can generate a vacuum pressure of 60” to 90 ” of water. That measurement referrs to how high the machine could lift water in a pipe. A single stage bag or cartridge type dust collector typical of the ones used in many home shops will move a much larger volume of air than a shop vacuum, but it much lower pressure and thus at lower velocity. A 2 hp collector might be able to pull 800 to 1000 CFM (10X more than a vac) but only generate 10” of vacuum presure. So, finally we get to the original question ”does a chip separator increase suction?” NO. It reduces suction. Every time you change the direction or speed of air flowing through a system it requires energy. A bunch of crooked pipes and hoses increase the resistance of air to flow and thus take away some of the velocity and pressure you had available. A chip separator does the same thing. BUT, the advantage of a chip sepatator is that it removes the chips and some of the dust from the air stream and that allows the system to run longer before the filter bag or cartridge gets clogged up. It is usually easier to empty the container of a separator than the bag on the collector. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#2 posted 81 days ago |
Not to strat a fight, please. I hope this help. -- Bert |
#3 posted 81 days ago |
I think this has been well covered; only one thing to add – Crank is correct that the chip separator will reduce your suction by adding resistance. However, if you look at the suction over time as you collect dust, the suction will drop off more slowly than it would have without the separator. This is because the separator is removing dust that would have loaded up the filter and cut the suction. If the curves cross, the separator system could average higher suction than the same system without the separator, but not always. I had a PM single stage DC and did a trashcan separator/Wynn filter modification. It did a noticeably better job trapping fine dust, but the overall suction took a big hit as both changes reduced air flow. It did a better job trapping what it sucked up, but it sucked up a lot less. I ended up going the ClearVue route. Bert – Blower or sucker would depend on which side you were standing! :-) -- John |
#4 posted 81 days ago |
The info above is really well stated. I only add that cyclones will normally have larger motors and impellers to move the same amount of air that a single stage DC will have. This is due to the cyclone adding drag to the system (reducing air flow). Some of that is made up by cyclones having more efficient impellers, since they don’t have chunks of wood hitting them…but all in all the separator will add drag, not reduce it. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 81 days ago |
Blower or sucker would depend on which side you were standing! I am always glad to show what can be done with an inexpensive HF Dust collector. In the last Fine Woodworking magazine issue they ran some test , they found out that for a small system,a Thien separator does as good a job or better than a cyclone would do at a fraction of the price . -- Bert |
#6 posted 81 days ago |
Thanks everybody for the good information. I understand the concept better now. Bert, from your picture the is almost what I was thinking of doing. With the exception of the bag and filter I am thinking of venting to the outside. Did you find a significant advantage to your set up verses the stock set up? Enough to justify the cost of the upgrade? -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
#7 posted 81 days ago |
From what I am hearing the only way to increase suction is to increase airspeed. Since the speed of the motor is fixed, could I accomplish this with a belt/pulley system like on a variable speed bandsaw? Place a small pulley on the fan shaft and a larger one on the motor shaft. -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
#8 posted 81 days ago |
If you increase the speed of the fan, you place more stress on the motor and the motor is usually matched -- As ever, Gus-the 74 yr young apprentice carpenter |
#9 posted 81 days ago |
I am hearing the only way to increase suction is to increase airspeed To vent outside is good as long as you do not have neighbors, neighbors will not like the noise nor the dust. Suction is the results of many factors, all important: dust collector Horse power, diameter and smoothest of the lines/hoses/pipes, restrictions ( such as fittings), length of the lines and so on. All factors must be taken into consideration. If you are just starting and you use only one tool at the time , the HF dust collector is the way to go , if your shop grows you will over grow it after a while but to start, it is a great DC. -- Bert |
#10 posted 81 days ago |
My bandsaw reference was only to illustrate what I was talking about with the pulley system to increase fan speed. I have the same HF dust collector that you do but it is currently in the stock configuration. I have neighbors but I don’t like them very much lol just kidding. Where I plan to vent outside shouldn’t bother anyone. What is the name and size of your canister filter Bert? I really like what you have done with that configuration. Bluepine, I see what you are saying about adding stress to the motor, I’m just thinking out loud and trying to find a way to get max performance. -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
#11 posted 81 days ago |
http://www.wynnenv.com/cartridge_filters.htm I also cut in window in the trash can wall, to see when it get full. -- Bert |
#12 posted 80 days ago |
I have pretty much exactly the same setup as Bert shows. I believe that it didn’t hurt airflow from the stock setup as much as you might initially think because changing the outlet from a curved pipe to a straight pipe (and in my case from Flex to smooth, a chunk of 5” stovepipe works perfectly as a coupler there FYI) reduces the loss from the flex/pipe curve. This was fairly significant when I did some ad-hoc testing without the separator in place yet. Not relevant to you (since venting outside++), but with the separator and bags/filters I think you might get close to break even in the long run because you’re dumping less junk into the filter so you have less loss there, but I’m not positive on that. The thein discussion board has some really great data on it. There is one thread here:
http://www.jpthien.com/smf/index.php?topic=563.90 |
#13 posted 80 days ago |
The people on the Thien forum have way way too much time on their hands. -- Bert |
#14 posted 80 days ago |
b2rtch ==== AMEN -- Live to tell the stories, they sound better that way. |
#15 posted 80 days ago |
#1 with outside venting is a bad choice for you if you heat your shop. removes to much heat, and if you heat with wood it will cause a negative pressure in the shop and draw through the shop(smoking out the shop).
#2 you have to watch you amp draw when you start opening up air flow. if you take a blower and remove all restrictions it will speed up to its max and my draw to many amps causing it to burn up. the 3HP cyclone I built draws 21 amps at it’s most open, but with the restriction of the cyclone, and filters it draws right at 16 which is just barley in it’s limits.
#3 when it comes to overdriving the impeller, you could speed it up to 4000 rpm safely. that’s only 400 rpm over factory. I thought the same thing double the speed with a jack shaft, but most impellers are poorly made and even worse balancing. Imagine a 12” steel impeller poorly balanced spinning at 6900 rpm (that’s double). then through a small chunk of wood at it. sounds like shrapnel to me. http://billpentz.com/woodworking/cyclone/index.cfm |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6149 |
