Joining Plywood side and bottom of a cabinet
Forum topic by damnHippie posted 435 days ago 1251 views 0 times favorited 12 replies Add to Favorites Watch
View damnHippie's profile
damnHippie
29 posts in 674 days
435 days ago
Topic tags/keywords: question joining
I’m in the process of designing/building a sideboard cabinet. A bit in the craftsman style, and has legs and rails. I’ve run into a design issue: how do I join the side plywood sheet and the bottom plywood sheet where they meet the rail? What do you think?
Classic butt joint with biscuits?
Butt joints, with biscuits
Rabbeted rail with both ply sheets mitered?
Rabbeted rail, mitered ply
Rabbeted rail, with the side ply sheet rabbeted?
Rabbeted rail, rabbeted side ply
Rabbeted rail, with the bottom ply sheet rabbeted?
Rabbeted rail, rabbeted bottom ply
-- 10 fingers, 2 eyes, and healthy lungs. for now. :P
View ajosephg's profile
ajosephg
443 posts in 460 days
435 days ago
I like option 3 or 4. Six of one or a half dozen of the other. They both hide the cut end of the stock, probably stronger and easier to make than 2.
-- Joe
View sIKE's profile
sIKE
1094 posts in 653 days
435 days ago
Sliding Dovetail?
View lew's profile
lew
4508 posts in 654 days
435 days ago
I would go with the last option simply because both side and bottom have the full width of the rail rabbet for support
View cmaeda's profile
cmaeda
192 posts in 453 days
435 days ago
The last option looks to be the strongest.
View gusthehonky's profile
gusthehonky
131 posts in 641 days
435 days ago
4 looks good for bottom, but side also must be taken into account also. What size ply, is there a face frame, fixed shelfs, or other material, aside from top and back to for support and strength?
-- Ciao, gth.
View roman's profile
roman
1125 posts in 792 days
435 days ago
Option 3…............only I wouldnt rabbet the base to the cabinet, rather let the cabinet sit on top. This way transportation and installation is faster, easier and it does not deter the structural integrity of the piece.
2 cents
View Joe Lyddon's profile
Joe Lyddon
486 posts in 951 days
420 days ago
With plywwod having grain(s) that go in both directions, alternating sheets, why not the good ole Butt Joint?
I have found it to be very strong and good when gluing pieces of ply together.
View CessnaPilotBarry's profile
CessnaPilotBarry
1291 posts in 602 days
420 days ago
I’d run the legs all the way up, with hardwood stringers mortised in. Plywood would only be used for the bottom, with a hardwood edge, and notched for the leg clearance.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View brianinpa's profile
brianinpa
1365 posts in 622 days
420 days ago
#4 will be the strongest joint out of all your designs, but I have to agree with Joe’s comment about a simple butt joint.
View tooldad's profile
tooldad
456 posts in 614 days
420 days ago
My method is to run the plywood all the way to the floor and use the plywood as part of the leg or side. Then add the solid material as a base trim. I think it would give you the same effect visually, then it is just a simple dado. I will draw it up in sketchup and post again.
tooldad
420 days ago
here you go:
dado with trim example
3055 posts in 921 days
420 days ago
Tooldad:
Your last design depends on a level floor.
Good luck finding one.
Go back and read what Roman tomentioned above.
It’s a shame to have to flip the cabinets over on the jobsite and start trimming plywood to level the boxes.
Cheers
