| Forum topic by JesseTutt | posted 86 days ago | 409 views | 0 times favorited | 11 replies | ![]() |
86 days ago |
Topic tags/keywords: question push blocks I have various plastic push blocks that I have acquired over time. Recently I noticed that the set I keep with the jointer are slipping. By this I mean that as I try to push the wood through the jointer the push blocks slide on top of the wood instead of griping the wood and forcing it through the machine. So od push blocks go bad? Do I need to restore them somehow? If so how? -- Jesse, Saint Louis, Missouri |
11 replies so far
#1 posted 86 days ago |
They do! -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#2 posted 86 days ago |
Drywall sanding tools work well too. I screw them to a wooden piece with a hook on the back end. Having several pushers, each with a different sized hook, allows for jointing various thicknesses. This works better than those pads with no hook. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#3 posted 86 days ago |
I make my own and when they do I replace the sandpaper. -- Bondo Gaposis |
#4 posted 86 days ago |
I contact cement sandpaper to mine when they begin to “lose their grip” -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#5 posted 86 days ago |
I have built several jigs that need handles. I think that the old push blocks will be turned into handles. Thanks for the information. -- Jesse, Saint Louis, Missouri |
#6 posted 86 days ago |
I had much the same push blocks, yellow in color and after a while they just seem to get relative hard and I felt as though the jointer was going to kick the board out from underneath the block. I currently use grout floats that I purchased at Home Depot for 4.00 each. Wooden handle with aluminum back plate I also use a grey plastic plaster sanding tool that I purchased at the depot as well. Both are larger that the yellow push blocks and have a more comfortable feel. Both really stick to the wood, so I feel safer and comfortable using them. |
#7 posted 86 days ago |
I screw truss mending plates to the bottom of my jointer paddles. I use them for rough lumber, because the dimples left behind are removed at the thickness planer. See my tip in the April 2013 FWW magazine. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#8 posted 85 days ago |
Yep, but they are so cheap I just buy new ones, though I’ve heard of guys using mouse pads to renew the old ones. I recently bought some Bench Dawg Push-Bloc, they are so superior to the more common design that they are worth the extra $5 or so each. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#9 posted 85 days ago |
When we moved into our house, my wife went a little crazy at the dollar store on rolls of rubber drawer liner for some reason. I’ve made a couple sticks out of scrap plywood and glued little pieces of that onto the business end, it works pretty well. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#10 posted 85 days ago |
I second the mouse pad idea. I scraped off the old pad and used contact cement the glue on the new mouse pad. -- Keith, Charlotte, MI www.julyswoodworks.com |
#11 posted 85 days ago |
It’s He!! to get old. Andy, BinghamtonEd’s idea struck a chord with me. I use that stuff on my bench to hold pieces for sanding. Should work great for push blocks. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15801 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
