| Forum topic by cajunpen | posted 502 days ago | 544 views | 0 times favorited | 13 replies | ![]() |
502 days ago |
Has anyone used the Incra Universal Positioning Jig on their Router table yet? Shop Smith had a great review on them in this issue and I’m bitting at the bit to order one. Just wonder how difficult they are to master. Any suggestions/comments? -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
502 days ago |
WoodSmith? -- We must guard our enthusiasm as we would our life - James Krenov |
502 days ago |
Yes, It was WoodSmith – at least I think. I am running out of steam tonight and the mind is on it’s way to bed. -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
502 days ago |
I have the Incra system on my table saw and router table. It’s called the TS3 when it’s mounted on the saw. But I have the router surface mounted to the right of the table saw making a wide table. and the Incra works on both tools. I’ve not used it for dovetails, because I have the Leigh Jig. I had the older version of the positioning system and upgraded to the LS version. I’m very happy with it. In face I modified my sliding table on the table saw and put an Incra Gauge on it to allow for more accurate wood cutting (in Length). -- Karson Southern Delaware karson_morrison@bigfoot.com |
502 days ago |
I do not own it but used it once at a friend’s shop. It seemed nice. For me, I probably would not purchase it for my shop. Part of the fun for me is creating jigs and trying to make the fixtures on my own. That said, the Incra did what it said and worked well. I love their miter guages, but again, I ended up creating a fence to attach to my normal cast iron guage. Write a review if you end up getting it! -- Jeff, South Carolina |
501 days ago |
Bill: I just looked at the Woodsmith article. That is a plastic jig I believe, The one that I have is full metal. I don’t know how this version works. I believe that this is a re-issue of the first jig that they made. It’s a less expensive jig than the all metal ones. -- Karson Southern Delaware karson_morrison@bigfoot.com |
501 days ago |
Yes Karson, it is a plastic jig – don’t know how well it will hold up, but it’s one of those things that I saw and “had to have”. I ordered it today, as well as the wooden hinge jig. I will post something on it after I’ve had a chance to play with it. If it works as advertised, I’ll use it until it plays out then upgrade to the aluminum set. -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
501 days ago |
I’m still working the heck out of my original Incra Jig Ultra. Great for doves, box joints, sliding doves and any situation where you need to sneak up to the perfect cut by thousands of an inch. The original is anodized aluminum, but all the indexing teeth on the fence and crossbeam are plastic. Love it! -- "Bordnerizing" perfectly good lumber for over a decade. |
500 days ago |
I’ve been using the jig for a while and really do like it. Mine is all plastic and very accurate. Mine came with a video that was very helpful. I’d say it’s worth the money. The mastery part took some practice. I use it mainly for half-blind dovetails but have done box joints and sliding dovetails as well as used it with edge forming bits. You’ll really like the way you can sneak up on the final cut. -- Nicky |
500 days ago |
Thanks Douglas and Nicky – I feel like I made a good choice. My real passion in woodworking is boxes – I’m thinking that the Incra just might be what I need. Do you guys leave it on your table all the time – of just when you need to make a joint? I’m wondering if it is appropriate for “everyday” routing needs. -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
500 days ago |
doesn’t one fish with plastic jigs? just a question…. -- Carpe Lignum - Seize The Wood, |
500 days ago |
I’ve been using the Incra Jig Ultra on the Woodpeckers Router tabel for about 7-8 years and liked it so much I bought the table saw fence (TS-3) for my contractors saw. I t was a great upgrade. When I bought my Unisaw I thought about using it instead of the Beismeyer that came with the saw but didn’t. Incra makes a great product the fence is extremely accurate and easy to use. The fence can be set at 1/32 inch intervals the has a micro-adjustknob for even smaller adjustments. Also the built in tape makes it easy to reset the fence at the exact setting for great repeatability of previous cuts. It’s great for other jobs other than dovetails and boxjoints. My advice its skiip the plastic jig and look for the aluminum model . If you have a router built into your table saw extension you can use the table saw fence for both table saw and router. Check out Woodpeckers.com. or my shop tour video on this site, The Great Barn Tour. Search this site for Challenge02 Any Q’s email me. -- DocK, WV |
499 days ago |
I honestly have never used one, but I’m jonesing for one after I saw it at woodcraft |
446 days ago |
Hi, See my blog entry about it here: http://www.intheworkshop.info/incra/index.html Just last night I made a “Greene & Greene style” exposed box-joint for a desk drawer (irregularly spaced pins). The Incra made it easy and painless. The jig is expensive (and takes up a lot of room), but very good. -- -- Matt Sanfilippo, Pittsburgh, Pa., www.intheworkshop.info |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1225 |
1660 |
120 |
335 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
926 |
LumberJocks.com Site Feedback
268 |
