is this a good deal?
Forum topic by distrbd posted 02-26-2013 08:57 AM 901 views 0 times favorited 7 replies Add to Favorites Watch
View distrbd's profile
distrbd
2252 posts in 2409 days
02-26-2013 08:57 AM
I have an opportunity to buy a used 16.5” DELTA floor standing drill press for $150 (OBO) ,If it all checks out the the chuck and quill is in good shape and the shaft is straight,would it be a good deal?
I only saw the ad a week ago and the seller wanted $250,but Today it got reduced to $150 probably because it looks so rusty which I don’t mind,I just offer him $100 .
Your opinions are appreciated.
-- Ken from Ontario, Canada
7 replies so far
View JesseTutt's profile
JesseTutt
854 posts in 2073 days
#1 posted 02-26-2013 03:08 PM
Check the standard things like runout of the chuck (I put a rod in the chuck and attach a dial indicator to the table and then manually rotate the pulleys), ease of movement of the quill. Another LJer had a problem in that the motor failed the day after he bought one, so you might ask to start / stop it several times. Also try drilling wood with a sharp bit the drill press should not bog down.
View toolie's profile
toolie
2120 posts in 2591 days
#2 posted 02-26-2013 03:27 PM
kinda hard to evaluate, sight unseen.
distrbd
#3 posted 02-26-2013 03:36 PM
Toolie, I basically would like to know if a Delta 16.5” drill press is a good choice ,if it prematurely breaks down ,if it has a weak part that commonly breaks,and your experience using it if you own one.
Jesse,You made some good suggestions,I was going to use a drill bit to check the run out,stat/stopping it I never thought of ,also a good idea to actually drill some thing with it.
Thank you both.
Ken.
View Tedstor's profile
Tedstor
1643 posts in 2595 days
#4 posted 02-26-2013 04:57 PM
Assuming its in good shape, $150 would be a swell deal.
A similar, new machine would cost twice that.
As long as it powers up, spins freely, and doesn’t have noticable run-out…...I’d buy it. Re-selling it shouldn’t be hard if you decide you don’t want it.
View JayT's profile
JayT
5586 posts in 2173 days
#5 posted 02-26-2013 05:21 PM
+1 to Tedstor.
View shampeon's profile
shampeon
1775 posts in 2146 days
#6 posted 02-26-2013 05:30 PM
Yes, that’s a good deal. In addition to all the rest of the advice here, check the pulleys to make sure they’re not chipped or anything. That’s a big machine, too, so make sure you’ve got a way to get it home. It won’t fit into the back of a sedan.
I’d figure on at least replacing the belt, since old belts tend to stretch and cause vibration, but that’s maybe another $20.
distrbd
#7 posted 02-26-2013 10:48 PM
Wow Great advice from all of you,I just spoke to the owner ,he accepted my offer of $100 and is willing to bring it to me,I know I’m taking a chance here but he tells me he’s going to a welding school and got the old drill press from his shop supervisor who had just replaced all the DPs with new ones.
Sounded honest ,and for $100 as mentioned it’s not a big gamble and can be sold for at least the same price.
I’ll let you all know once I try it out.
Update: The owner just called and said he just tested the DP for run out and unfortunately he says “it does have a bit of a wobble” so the deal is off,I have no reason not to believe the guy,in fact I’m glad he tried it before driving to my place just to find out it’s a useless tool.
, it just wasn’t meant to be. Thank you all for your inputs
