| Forum topic by Kevlar | posted 82 days ago | 358 views | 0 times favorited | 6 replies | ![]() |
82 days ago |
Hi experts, Recently joined and just don’t have enough time in the day to enjoy the wealth of information on this site…so excuse the question if it has already been posted. I while back I picked up a Craftsman band saw in a package deal – it has a blade width of 3/8”...is there a reason I can’t drop that to a 1/4” or 1/8” blade – Sorry new to band saws. And more importantly, what type of adjustments need to be made. It did not come with the manual and I have been searching with no luck so far. Thanks all! Wiqar -- ~ Wiqar |
#1 posted 82 days ago |
Band saws can use varying widths of blades. Smaller ones are better for cutting tight curves and larger ones are more for resawing. Be cautious when tensioning – thinner blades need less tension to cut properly and could snap. -- -=Pride is not a sin=- |
#2 posted 82 days ago |
Wiqar I might be able to help just have a starting question, what size is your bandsaw? 9” bandsaw I wouldn’t go larger then a 3/8” 14” max 1/2” Anything larger you can go to the larger blades such as 3/4 and up. Here is a video that you also might find helpful. -- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs |
#3 posted 82 days ago |
Thanks Randy – it is a 10” saw…I would like to drop to a 1/4” or 1/8” blade for finer cuts then back to the 3/8” blade for rough cuts. I finally found the manual online, but have not reviewed yet. Thoughts? -- ~ Wiqar |
#4 posted 82 days ago |
The guides may limit how small a blade you can put on it. You should check how adjustable they are. Anything less than an 1/8” blade would likely require better guides. Also, don’t over tension the smaller blades. Most consumer bandsaws can’t even tension the bigger blades enough but they may be able to over-tension the smaller ones and that could lead to breaking a blade. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#5 posted 82 days ago |
I got the feeling you should stick to 3/8” and 1/4” blades. 1/4” blades for general use. -- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live" |
#6 posted 82 days ago |
Surfside, 3/8 – 1/4” won’t give him the turn radius he’s likely to want or need, I’d try a 3/16”. I’m no expert on the smaller saws but if I can run smaller blades on my 14” Kevlar should be able to run smaller then 3/8” on that 10”. -- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
