Looking for a 5 inch DC hose port
Forum topic by MT_Stringer posted 02-26-2013 03:51 AM 1536 views 0 times favorited 22 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3172 posts in 3253 days
02-26-2013 03:51 AM
Topic tags/keywords: question
I want to replace the dual 4 inch hose port that came with my 2HP Harbor Freight dust collector. It will make for a straight run from my chip separator into the inlet of the blower.
The problem is I need an adapter that is 5 inches ID on one end to fit over the machine port (like the dual port does now) and 4 inch OD on the other end to accept a 4 inch hose. No luck so far. I bought one from Rockler – didn’t fit. :-(
If you are confused, check out my installation.
Your thought and advice appreciated.
Thanks
Mike
22 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2308 days
#1 posted 02-26-2013 03:58 AM
Hmmm…. the adaptors I’ve seen are all sized at ID, so that a hose of the appropriate size will fit over them. Any possibility of using a short piece of 5” hose from the machine to the adaptor?
-- John, BC, Canada
MT_Stringer
#2 posted 02-26-2013 04:20 AM
The outlet from the chip separator is 4 inches (Rockler kit). I haven’t found any 5 inch hose but I may order some when I order the filter from Wynn.
nwbusa
#3 posted 02-26-2013 05:00 AM
View JesseTutt's profile
JesseTutt
854 posts in 2132 days
#4 posted 02-26-2013 05:18 AM
how about making a wooden donut with an ID to fit over the 4” port and an OD that will just fit a piece of 5” hose?
MT_Stringer
#5 posted 02-26-2013 05:46 AM
“how about making a wooden donut with an ID to fit over the 4” port and an OD that will just fit a piece of 5” hose?”
It’s beginning to look like that is my only choice.
woodbutcherbynight
4816 posts in 2431 days
#6 posted 02-26-2013 05:48 AM
Exactly my thought.. Why bother with ordering one when you have what you need to make one. I replaced a warped plastic cut off on my blast gate last week with some time, scrap wood Bearpaw gave me, and some attention to detail. Works great, now I have the sudden urge to do them all the same way. So many projects so little time….. (laughing)
A second thought would be to look in the plumbing department, never know what might fit.
4996 posts in 2515 days
#7 posted 02-26-2013 12:55 PM
If you run a 5” hose to a 4” port, you may as well stay with 4” hose. That said, you can make a 5” port on the blower by cutting a plywood circle that replaces the plate. Then fasten a 5” HVAC starter coller on it.
View MarcusM's profile
MarcusM
57 posts in 3002 days
#8 posted 02-26-2013 02:05 PM
Mike, if I understand you correctly, the port on your DC is a 5” and you want to reduce it to a single 4”? If so, they make an HVAC 5” female to 4” male reducer that is readily available.
Regards, Mark
-- Tilbilly Mark
#9 posted 02-26-2013 02:12 PM
After reading what Mark said, I reread the original post and now see the light (I think). What Mark suggested would be the easiest.
JesseTutt
#10 posted 02-26-2013 02:12 PM
Fred, I thought that the rule was to always run the bigger size pipe as far as possable and then reduce to the size of the fitting.
#11 posted 02-26-2013 02:26 PM
A better rule is to upsize all the ports to the size of the ducting. That’s not always possible, so generally running the larger pipe as far as possible before reducing is considered the way to do it. But when you have a 4” prt, you can move maybe 400 CFM of air. Fill that 400 CFM with chips, and let it enter a 6” pipe, and the speed slows, maybe enough to drop the chips out of the airstream and cause a clog. In general, you want to avoid doing that.
View needshave's profile
needshave
175 posts in 1981 days
#12 posted 02-26-2013 02:29 PM
Take a look at Fernco Flexible couplings. They are rubber couplings that come in a variety of different sizes and designed to adapt to a variety of different sizes. They can be found in some big box stores but all major plumbing houses. They are designed for plumbing applications so they fit very well and seal really well.
I have two on my system, without any problems. I’m sure they have a web site.
View ldl's profile
ldl
1135 posts in 2387 days
#13 posted 02-26-2013 02:33 PM
I would turn a sleeve with a lip that the 5” hose would go inside then screw sleeve to separator and seal the 5” hose to inside of sleeve. That way no turbulence with a thicker sleeve land.
-- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - -
MT_Stringer
#14 posted 02-26-2013 06:07 PM
”Mike, if I understand you correctly, the port on your DC is a 5” and you want to reduce it to a single 4”? If so, they make an HVAC 5” female to 4” male reducer that is readily available.”
That sounds like what I am looking for.
”Take a look at Fernco Flexible couplings”
I found what I think would fit perfectly at this company. Now if only I can find it locally.
Thanks for all of your replies and suggestions. I have 4 inch hose or PVC (Sewer and Drain) piped up to a manifold that connects my table saw, router table and an open ended port with a blast gate. The four inch goes into the plastic drum. From there it is connected to the suction of the blower. That’s where the problem lies. The dual suction ports are 4 inchers (for hose connection and the blower housing is a 5 inch OD.
I will check the big box stores again for the rubber coupling and maybe check with a local HVAC supplier. Last time I was there, they didn’t have much.
My projects are piling up.
Thanks again.
Mike
needshave
#15 posted 02-27-2013 12:36 AM
MT…I get my fernco’s at the regional plumbing supply house. They carry a vast inventory. Plumbers will be more prone to have it than HVAC. Hope it works for you.
