| Forum topic by Manitario | posted 114 days ago | 674 views | 0 times favorited | 13 replies | ![]() |
114 days ago |
Topic tags/keywords: stabilizing wood Hey all,
I have a large slab of redwood burl that I want to make into a coffee table. As you can see from the pics, some of the wood on the edges is pretty soft. I have read about turners using epoxy/CA glue to stabilize wood for small turning projects, however I’m not sure how I’d use CA glue to stabilize the large edge of this slab. I have also read about using Polycryl to stabilize punky wood. Anyone have any suggestions or actual experience stabilizing large areas of punky wood like this? I’d rather not cut the edge back if I don’t have to…
-- Rob, Sault Ste. Marie, Ontario |
13 replies so far
#1 posted 114 days ago |
pour on epoxy , only way to go in my opinion’ |
#2 posted 114 days ago |
Thanks Charles; can I just simply pour the epoxy onto the edges after I clean them up a bit? -- Rob, Sault Ste. Marie, Ontario |
#3 posted 114 days ago |
yes you can , I prefer to thin the first coat about 25 % with acetone and brush it on and let it soak in well, after that you can either finish with another coating or continue with the epoxy ,Lowes has one by Zinnzer that I have used. Some of the craft stors has one called Enviorlite, its actually a polyester, but behaves the same. Redwood is beautiful, but very soft, I would do the entire thing to “firm up the ” wood. |
#4 posted 114 days ago |
Pour on epoxy will work. If you’ve never used it before, put something on the floor to catch the mess. First time can get ugly. As for CA, it works great but it would take a lot to do those edges. Water based poly could work as well. Let itsoak in and dry. It wworks on my blue pine anyway. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#5 posted 114 days ago |
I just realized who gave you the original epoxy advice. My advice then becomes, do whatever Charles tells you and you’ll be fine. :-) -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#6 posted 114 days ago |
Thanks again Charles, the Envirolite that you suggested for my last project worked really well. I like the idea of being able to thin the epoxy a bit with acetone; hopefully it’ll soak into the edges a bit better that way. -- Rob, Sault Ste. Marie, Ontario |
#7 posted 114 days ago |
Rob, Let us know when you start marketing those arm bands. We all need one! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#8 posted 113 days ago |
This should be of use to a lot of people, good post. Didn’t realize that stabilizing stuff was readily available. -- Jim, Anchorage Alaska |
#9 posted 113 days ago |
Will this process work on all types of wood? I have spalted maple that I need to stabilize. -- Coach Mancuso |
#10 posted 113 days ago |
yes sir , it works well on any wood, the key is do the first coat or 2 thinned so it can soak it up. as to the arm bands (LOL) , just ask, glad to help if I can |
#11 posted 113 days ago |
Haha, you definitely don’t want to use CA on that much, the fumes will kill you. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#12 posted 113 days ago |
There is also a Minwax Wood Hardener product that is basically thinned out Epoxy I have used on some rotten patio furniture that works pretty good. -- Mauricio - Woodstock, GA - "Confusion is the Womb of Learning, with utter conviction being it's Tomb" Prof. T.O. Nitsch |
#13 posted 113 days ago |
You will have to protect the epoxy from UV light, sunlight, with a Varnish that has UV protection. Marine varnishes are really good. I use epiphanes. I think it is available in the US. Jef |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
