Forum topic by lumberjoe | posted 02-25-2013 02:46 PM | 1874 views | 0 times favorited | 22 replies | ![]() |
My wife wants a farmhouse style table for our dining room. I plan on making the table and benches out of walnut. The only thing I can’t really figure out is how to keep the laminated top looking like separate boards. Is this just stickered underneath like a picnic table with a tiny gap (dollar bill) between the boards? I was thinking of maybe cutting a very slight chamfer in all of the edges pre-glue up but I ‘m not sure that would look right |
22 replies so far
#1 posted 02-25-2013 02:50 PM |
Joe: And after about a year or two? All I heard was: Looks great if you can keep it clean…lesson learned. -- Tsunami Guitars and Custom Woodworking, Cleveland, TN |
#2 posted 02-25-2013 02:55 PM |
Good tip (and ammo). I like the overall style – chunky and square with huge breadboard ends, I do not like the plank look. Every bone in my body wants to make seamless joints. I’ll raise that issue and see if it gets me anywhere |
#3 posted 02-25-2013 02:55 PM |
you can use a v-grooved t&g. Use a very slight v which gives the appearance of separation and helps eliminate the issue Paul speaks of. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#4 posted 02-25-2013 02:58 PM |
I thought about that too Don, but it may look too “on purpose”. I’ll try it out on some scraps and see what it looks like. |
#5 posted 02-25-2013 03:01 PM |
That example in the picture looks like the boards on top If you glue it up and use breadboard ends you have to |
#6 posted 02-25-2013 03:07 PM |
your other option is a ship lap, but then you have the original “food in the crack” issue”. My table has a crack like a separate board, and my wife doesn’t complain, but the crack is more like 1/16” -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#7 posted 02-25-2013 03:10 PM |
Have you considered gluing a 1/8” or 1/4” strips of a different wood between the planks. You could have the look with out the cracks. -- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford |
#8 posted 02-25-2013 03:20 PM |
Joe, 30 years ago a friend and I worked as carpenters at a large apartment complex in Atlanta. The super wanted some tables for outside use that looked “Rustic”, “Elegant” “Not Picnic tablish”, and easily cleaned. We got pine 2×12’s, planed them (by hand with crappy planes), and cut bread board ends using 2×6’s with M&T joints. finish was some combination of extra cans of stain that turned nearly black, top coats were Spar Urethane Varnish. -- Improvise.... Adapt...... Overcome! |
#9 posted 02-25-2013 03:44 PM |
I am still learning how to do joints. So if you want crappy joints I will come do them for you :-) I do hate leaving the gap. -- Mother Nature created it, I just assemble it. |
#10 posted 02-25-2013 04:17 PM |
When I was in High school I made a table just like that and what I did was chamfer the edges with a chamfer bit then use a sharpie to black the bottom to resemble a 1/16 gap. Then after gluing them up I filled the chamfer in with clear epoxy and then finished. The result was the visual effect of the rustic planks with a continuous smooth surface with no gaps to collect debris. -- If guns cause crime all of mine are defective Randy |
#11 posted 02-25-2013 04:53 PM |
Hand plane the v groove bevel for that “not machined” look and ship lap em like Don says. Depending on your finishing schedule the freshly planed bevels will take a little different than a sanded top. -- Its not a crack, its a casting imperfection. |
#12 posted 02-25-2013 05:18 PM |
Just plumb an air compresser line by the dining table to blow out the salt and crumbs. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#13 posted 02-25-2013 07:37 PM |
Notice how that breadboard end is pegged, so that when the timbers shrink, the gap opens up. I have made a couple of tables like this, tongue and groove, the t&g planks are not glued together, the breadboard end is glued at the outside edges and centre. Prefinish the tongues before putting it all together, so you don’t end up with an unfinished line between planks when they shrink. |
#14 posted 02-25-2013 07:40 PM |
My two pence: make it out of pallet wood and stain it ;) -- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes... |
#15 posted 02-25-2013 07:45 PM |
I don’t allow pallet wood in the house. I know a lot of people use it but that stuff is nasty. Renners, that sounds perfect and the way to go. So if I understand you correctly, just T&G the all the boards, leave them loose (no glue/stickers) and breadboard the ends. Should I peg each board, or every other board since the outermost and the center will have some glue? |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
