coner base cabinet , pull out vs lazy susan
Forum topic by Pabs posted 114 days ago 833 views 0 times favorited 9 replies Add to Favorites Watch
View Pabs's profile
Pabs
174 posts in 1651 days
114 days ago
hey all
I have a corner base cabinet that currently has a lazy susan. we use for bowls right now and I`m not too crazy about it. when fully loaded I find that it wobbles a bit and becomes hard to turn… if not careful, items fall off to the side and then you can`t turn the lazy susan, etc, etc…
I saw this a while back and I’ve been intrigued by it ever since
now I realize that by doing this you lose part of the cabinet, the area on either sides of the drawer sides.
but I`m thinking that by having a full pull out would give better use of the back space that is so often simply used to store things you never to!
as anyone built a cabinet this way? any thoughts on this are appreciated
thanks
Pabs
-- Pabs
9 replies so far
View Charlie's profile
Charlie
748 posts in 483 days
#1 posted 114 days ago
There are corner pullouts that articulate that will waste a lot less space.
Similar to this: rev-a-shelf
But there are lots of different kinds, manufacturers and styles. I’m sure some are better than others, but I’ve seen several in use in kitchens and they seem a lot more useful than the lazy susan for many of the reasons you mentioned.
Just google “corner pullouts” and you should get plenty to look at.
View Cosmicsniper's profile
Cosmicsniper
2155 posts in 1356 days
#2 posted 114 days ago
I have the exact same issue in my kitchen renew project. I’m strongly contemplating the same thing because I think there’s a unique wow factor to this design.
But, alternatively, I think the lazy Susan will work if you replace the crappy one for something better. My existing one is way too wobbly…and I get tired of that making things fall off the shelves and clogging up the works…especially when the kids spin the sucker a million miles an hour to get a pop tart.
However, replacing a two-shelf lazy Susan with a three shelf corner pull-out like that will give more actual shelf surface area, IMO. To me, a lot of space is wasted in a lazy Susan because items stored in it might not fill up all the head-space.
I think it just depends on what you plan on storing in it.
-- jay, www.allaboutastro.com
View huff's profile
huff
2597 posts in 1482 days
#3 posted 114 days ago
Pabs,
I’ve built a number of corner drawers and pull-outs over the years. I’ve never been a big fan of a lazy susan, so I have used a number of other options instead. Rev-a-shelf makes corner pull outs that articulate like was mentioned above that you can just buy and install.
Making a corner drawer or pull-out can be tricky, especially getting slides mounted firmly and aligned properly.(no square sides to mount to a use to align).
It does make one deep drawer though, (front to back) but the front of the drawer makes it a little awkward.
It does become the conversation piece of the kitchen when done properly! lol
-- John @ http://www.thehuffordfurnituregroup.com
View Pabs's profile
Pabs
#4 posted 114 days ago
yeah I’ve seen the rev-a-shelf style… but they are so expensive for what you get.
good point on the wasted space in a lazy susan… we use to store bowls mainly and it`s true that mush of the space between the shelves is simply dead air…have 3 or even four shallow drawers might be a much better use of the space even if there is the loss of space on the sides
-- Pabs
View huff's profile
huff
#5 posted 114 days ago
Pabs,
You also have a lot of wasted space with a lazy susan besides just the space between the shelves. A round shelf in a square box leaves quite a bit of wasted space also. I did my first corner drawer over 20 years ago because I didn’t have enough corner to get a lazy susan in and there was nothing on the market at that time, so I designed and built corner drawers, so the customer would not have just a dead corner.
The customer loved it and I thought I created the “new mouse trap” at the time. LOL. Only to find it available on the market a few years later.
View Monte Pittman's profile
Monte Pittman
7209 posts in 535 days
#6 posted 114 days ago
I hate lazy susans installed in cabinets. I love the pull out idea.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View DLCW's profile (online now)
DLCW
504 posts in 852 days
#7 posted 113 days ago
This is a standard corner cabinet setup I do in all kitchen project I undertake. A study was done and it was determined that you can utilize 36% more of a corner cabinets space by implementing this drawer system instead of a lazy susan. And nothing will fall off.
When I design corner cabinets, I build a square cabinet within the corner cabinet to install the drawer hardware. The big challenge is when you get to do a corner that will go into a corner that is not 90 degrees and you get to figure out all the angles of everything. Can be a bit of a PITA but is well worth it when the customers eyes light up and they are so thrilled with the results.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Pabs's profile
Pabs
#8 posted 113 days ago
thanks guys…
this helped in selling the idea to my wife (aka the foreman on this job!)
now I just need to get to work..will try and post the pics once done
cheers
-- Pabs
View Jerry's profile
Jerry
1477 posts in 1744 days
#9 posted 113 days ago
We use a nice rev a shelf all wood for the lazy Suzan, but when asked we will do drawers in the corner.
Just as has already been mentioned, we simply build a square box that installs inside the corner cabinet. I will also bring front of the cabinet across at 45 degrees instead of your common pie shape. Maybe not as much wow factor, but works quite well.
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
