how to dry green would without kiln
« back to LumberJocks.com Site Feedback forum
Forum topic by gregIND posted 02-25-2013 01:42 PM 1511 views 0 times favorited 8 replies Add to Favorites Watch
View gregIND's profile
gregIND
20 posts in 1921 days
02-25-2013 01:42 PM
Topic tags/keywords: question
I work at small pallet shop for my second job. we get new wood n to build some new pallets . it is pretty green when we get it . ive tried to use a few pieces and it warps over nite. is there any way to dry it without a kiln? like some small pieces for cutting boards? thanks for any input.
-- gregIND
8 replies so far
View JesseTutt's profile
JesseTutt
854 posts in 2108 days
#1 posted 02-25-2013 01:55 PM
A friend cuts logs into boards a little over an inch thick, stickers them and stores them in his attic with a heavy weight on top.
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#2 posted 02-25-2013 01:58 PM
Yes, you can air dry. Stack sticker and wait.
-- Bondo Gaposis
gregIND
#3 posted 02-25-2013 02:10 PM
thanks for replies but is there any way to do it quiker? would it work to put it n an old oven overnite on the lowest setting and if u store it in attic how long should u leave it there?
-- gregIND
View Post_Oakie's profile
Post_Oakie
84 posts in 2151 days
#4 posted 02-25-2013 02:12 PM
Part of the problem with using pallet stock (I’ve cut quite a bit of it) is that it is typically from logs too poor for anything else. Your best bet is to pick pieces as carefully as you can. Based on my experience running a portable sawmill, Post oak and hackberry tend to warp and twist as they dry. Yellow poplar is fairly stable and nice to work with. I have made some nice projects out of yellow poplar salvaged from pallets. Sycamore can be good, especially if quartersawn, but if the log had a spiral grain, the boards will twist as they dry. Try to get the straightest grain you can, with the growth rings centered on the board. Quartersawn is good, but not if it has the juvenile wood (within 1/2” of the center of the growth rings).
Indoors, in an out-of-the-way place, 4” off the floor and stickered with a fan or two to circulate the air through the stack is ideal. For something like cutting boards, a couple of months in the winter, maybe three months in the summer, depending on how humid your house is. Do a web search for “oven dry wood test” for info on measuring moisture content without a meter. It also turned up info on microwave drying wood—maybe someone on the forum has tried it.
-- Good judgement comes from experience. Experience comes from bad judgement.
gregIND
#5 posted 02-25-2013 02:28 PM
thank you Oakie that helps we jst got some real nice walnut and birch in and they both warped over nite the birch was the worst. still cant believe we are making pallets out of walnut . we are making some small crates out of it that will hold fertilizer made out of fish thats suppose to go in all lowes stores.
-- gregIND
Post_Oakie
#6 posted 02-25-2013 06:12 PM
How thick are the boards? I should have asked that before. Thinner wood is a lot harder to dry straight—some come out like potato chips. If possible select pieces more than 1” thick, dry, then rip to final thickness on a band saw. Walnut & birch? Guess I shouldn’t be surprised. Probably cut from large branches, which is almost impossible to dry straight. Nail them in place while green, and they’ll last long enough for a shipment.
gregIND
#7 posted 02-26-2013 04:47 PM
thanks oakie will try that most is over an inch
-- gregIND
View sprucegum's profile
sprucegum
324 posts in 1995 days
#8 posted 02-26-2013 05:17 PM
I sometimes dry small pieces that I am in a hurry for by putting them on a ceiling rack almost over my wood burning furnace in the basement. It gets pretty hot there and green wood will dry in 2 weeks if I am burning wood. Sometimes it twists and cracks painting the ends helps. usually I can straiten them out by flat buzzing them on my jointer. The good thing is you don’t have to worry about you project twisting when you put it in a warm dry house it has already been there done that. If you have a warm air oil or gas furnace it should work just a little slower.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
