Overhead pin router
Forum topic by liketosail posted 02-24-2013 11:55 PM 6135 views 0 times favorited 9 replies Add to Favorites Watch
View liketosail's profile
liketosail
31 posts in 1963 days
02-24-2013 11:55 PM
Does anyone have one of these and can tell me more about them?
This is what it should look like wheni I have it all back together. I had to take it apart to load it in my truck.
9 replies so far
View Loren's profile
10476 posts in 3670 days
#1 posted 02-25-2013 12:21 AM
They are useful for a pro. I have one. It’s very useful
for duplicating irregular parts from tempates and for
making forms for bent laminations.
The machine pretty much stays set up for duplication
using a pattern stuck to the bottom of the work
piece that rides against the pin in the table. The
spindle if directly aligned with the pin and so
the pattern does not interfere with the cuts
or get damaged. Pattern cuts can be made in
depth stages and a 3hp pin router will
feel about 3 times more as powerful than
a 3hp hand held router.
You can use it with a fence to plow grooves.
The machines are regarded by many as dangerous.
They are perhaps a little difficult to guard well
in a way that doesn’t interfere with vision
or feeding of the work piece.
They are used a lot by electric guitar builders
for routing body shapes and cavities.
Inverted pin routers are simpler to use safely
and command higher prices on the used market.
View Charles Wilson's profile
Charles Wilson
18 posts in 3793 days
#2 posted 02-25-2013 12:55 AM
I have two and find it a versatile piece of equipment.
As Loren said ,template or pattern work is a main use for most owners. I use mine for a variety of other uses as well,including grooving dado and rabit work as well as fluting. With a few simple jigs and setups a lot of work can be done with this type of machine. I consider them to be much more useful than a router table. As far as safety. is concerned ,care should be used as with any machine. Both my routers have a ring type guard around the spindle/bit which improves safety.
CW
liketosail
#3 posted 02-25-2013 01:15 AM
Thanks for the information, I drove 300 miles one way to buy this and plan to use it a lot in the future .
It is 3 phase and I got to see it run before I took it.
It was only $300.00 dollars so I believe it was a great buy.
I do need a manual and a few other things.
View DKV's profile
DKV
3940 posts in 2526 days
#4 posted 02-25-2013 02:17 AM
Loren and Charles, the concept sounds interesting. It seems people can make their own. Tell us more what you use them for.
Thanks
-- This is a Troll Free zone.
#5 posted 02-25-2013 03:06 AM
I’d like to know more about Charles’s jigs.
I have never seen any manual or instructional
video for pin router methods.
I have a smaller one too, a light model used in the
printing industry. I used to use it with small cutters
for slotting guitar bridges and making freehand
router jigs with slots for template bushings.
The one I use now is a 2hp Invicta model similar
to the JET shown.
Pin routers excel at making quick slotting cuts
that otherwise involve more fussy topside
router setups.
They can also bore holes really fast with the
pneumatic plunge. Chair legs can be shaped
and mortised quickly for joinery and back
rungs using templates.
The pin router at a given depth routes
every part to the same depth, no matter
what its thickness or irregularity on top.
A regular router or router table or inverted
pin router indexes depth by the depth of
the cutter.
View kizerpea's profile
kizerpea
774 posts in 2390 days
#6 posted 02-25-2013 01:58 PM
I have the shopsmith over arm pin router…dont use it much…but it comes in handy when i need it
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View helluvawreck's profile
helluvawreck
31351 posts in 2889 days
#7 posted 02-25-2013 02:22 PM
We had several over the years. You can get them for a reasonable price at industrial auctions. Although you may not use one everyday they are quite handy to have and an industrial model can do some heavy routing.
helluvawreck aka Charles
Charles Wilson
#8 posted 02-26-2013 02:16 AM
Here is a quick shot of one of my routers. Old iron for sure, but still has a lot of life left in it.
Loren,
I don’t have any pictures of the jigs I use,most of the time I just run one up as needed.
An important thing to remember is the relationship of the “pin to the bit. A pin with the exact diameter as the cutter is the easiest place to start.
1. trimming an overhanging veneer to a substrate. (use a starting block clamped to the table)
2. a fast and easy way to cut evenly spaced dadoes for shelves or dividers.(tack strips or blocks the the underside of an oversize piece of MDF using your parts as spacers for an exact fit the using stops or clamps to secure workpiece to the other side.)
3.using the same concept tack scrap to the underside of a workpiece to define cutouts or recesses for inlays or hardware.
Now if you change the bit to pin relationship by using a smaller pit than bit ,instant rabbit or stepped cut. Take that a little further and mortices and inlays can be cut with the same template.
A fence clamped to the table allows many joint type cuts dado grooves etc. Adding spacers to the fence setup allows evenly spaced or uneven spaced cuts to be made quickly, I use this for making fluted pilasters for furniture or door casing.
If you have any specific tasks in mind, let me know and I will try and take some pics or video to better explain.
CW
View woodworkercharles's profile
woodworkercharles
1 post in 1322 days
#9 posted 01-16-2015 08:50 PM
I just purchased a used JET overhead router in Kansas City. It is the medium blue color and is built like a bull. It has the pneumatic quill with 3 bushing sizes for the chuck. I used a Delta Rockwell a few years ago at Shawnee Mission West High School. I gave 600 buck for it. I am looking forward to using it on furniture and cabinets I custom build. Does anyone know where I can get a copy of a manual for it? I put new fence boards on it and probably will be using it soon. Right now I am figuring on a dust collection connection and making a shroud to funnel the dust into. I might get part of it…
