Working with Slippery Elm?
Forum topic by docspencer posted 87 days ago 325 views 0 times favorited 5 replies Add to Favorites Watch
View docspencer's profile
docspencer
94 posts in 115 days
87 days ago
I cut down a slippery elm this winter and was thinking about having it sliced into lumber. Has anyone worked with it? I hear it can be tricky – interlocking grain and all.
5 replies so far
View Monte Pittman's profile
Monte Pittman
7069 posts in 508 days
#1 posted 87 days ago
From the pictures of it, it looks like American Elm. With that said it can be a very beautiful wood. My recommendation would be to slab it thick initially to dry. 2-3 inches thick. When dry then resaw it to thinner widths. In my experience if you cut it too thin when it is green it’s nearly impossible to keep it from warping.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
docspencer
#2 posted 87 days ago
Just looking at the end of the logs it looks pretty nice. Thanks for the tip. The logs aren’t very large so this is more of an experiment. Thanks for the tip – now to see how much it’ll cost to have it sliced up.
View WDHLT15's profile
WDHLT15
686 posts in 646 days
#3 posted 87 days ago
When you sticker the lumber to dry, space the stickers on 16” centers. Put the best stuff on the bottom so the weight of the poorer stuff will work for you.
-- Wood-Mizer LT15
View REO's profile
REO
286 posts in 244 days
#4 posted 87 days ago
band the pile with tie straps coincident with the stickers. tighten the straps occasionally and weight it down heavily. You can cover the top with a sheet of plywood with a 2×4 perimiter (like a low sandbox) over a last row of stickers and use loose sand If you saw it 4/4 I would sticker it closer to 10 inches. cover it with some old cardboard, that will help it dry a little more uniformly than letting the air blow through it. As Monte has said it is squirley to keep flat. quarter sawing helps too.
docspencer
#5 posted 80 days ago
Quick update – I’m wondering if I might be able to slice the smaller diameter logs up myself. Chainsaw? Recip? Circular? Am I crazy?
