| Forum topic by docspencer | posted 89 days ago | 299 views | 0 times favorited | 8 replies | ![]() |
89 days ago |
I want to make a clock by laminating pieces of different woods together – basically a butcher block look but for a clock. I want to glue together pieces with gentle curves but can’t figure out how to cut the curves so they glue together tightly. Does this make sense? |
8 replies so far
#1 posted 89 days ago |
I think we need a photo or sketch to see clearly what you are trying to do. |
#2 posted 89 days ago |
Make templates out of 1/4” material with the curves carefully Pat Warner is a real expert in precision template routing |
#3 posted 89 days ago |
Templates – great idea. Wish I had a bandsaw – we’ll see how well my jigsaw cuts. I was looking for an excuse to buy a top bearing bit. I’ll draw a picture and post it Looks like I have to go through photobucket to post on this forum. Gotta figure that out. |
#4 posted 89 days ago |
Here’s a very rough drawing of the sort of thing I’m talking about. |
#5 posted 89 days ago |
Looks like half your sketch got chopped off. Same thing happened to me on my blog when I added photos via photobucket. Are you aiming for a mantle style clock? I’m guessing you want your laminations to be vertical, oriented left to right (or could be stacked top to bottom, or front to rear?) In any case, I’d first cut the curves to your pattern (a paper or light cardboard pattern), cut out close to to the line, staying outside it, glue them together, and then plane, rasp, and sand to the final shape. If you had access to a bandsaw, you could do the glue up first, then saw to shape. A wide belt sander would help in the shaping, and you could use the end of the sander (the drum or spindle end) for sanding the concave curves. A stationary sander would be best. If this doesn’t address your problem, let us know, and we’ll give it another shot. |
#6 posted 89 days ago |
Look at how they build the different drunken cutting boards. They stack 2 boards on top of each other and then cut out the curves. They then swap out the pieces and you have 2 of them with the woods opposite each other |
#7 posted 89 days ago |
Brilliant! |
#8 posted 89 days ago |
Looked that up. I think I get it. One question – what purpose do the thin little strips in between the curved pieces serve? |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15804 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
