workbench dogs
Forum topic by dpjeansonne posted 02-24-2013 04:03 PM 1670 views 0 times favorited 10 replies Add to Favorites Watch
View dpjeansonne's profile
72 posts in 3145 days
02-24-2013 04:03 PM
Topic tags/keywords: clamp plane joining
I saw a wood workbench design using T tracks embedded into the work surface. It was being used more like an assembly table which seemed just fine.
My question that could T tracks replace bench dogs where it holds stop blocks against an end screw or is T tracks not sturdy enough for holding boards in place for planning, chiseling, etc.?
Does anyone have any experience?
-- Cajun Don, Louisiana
10 replies so far
View PurpLev's profile
8534 posts in 3581 days
#1 posted 02-24-2013 04:27 PM
mechanically t-tracks should do just fine given that they are secured to the workbench over a long stretch with multiple screws.
that said, benchdogs are simply darn cheap – and simple to operate, you pop one in, you pop it out, done deal. no need to slide jigs up down the track, no need to screw/unscrew knobs, no adjustments required etc… just simple stop mechanism that relies on the vise to do the clamping. That simplicity and their traditional look is what I believe makes them so great.
that said, if you want t-tracks, use t-tracks.
View Stuey's profile
43 posts in 2889 days
#2 posted 02-24-2013 04:42 PM
As long as they’re screwed down every couple of inches they should be sturdy enough.
I would think that T-tracks are better when bench tops are not large enough for dogs. Plus they’re more versatile for hold-down clamp and jig placement.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2463 days
#3 posted 02-24-2013 11:05 PM
T-track would be a PITA when it comes time to flatten the top. You’d have to remove the track, flatten, deepen the groove and then reinstall.
Other than that, it would probably work just fine.
-- Mark Kornell, Kornell Wood Design
#4 posted 02-25-2013 12:48 AM
My thought was in making a bench from the start. I thought it would be easier to install a track than to cut or drill all the holes for benchdogs. Also the ability to use a variety of jigs and hold-down would be a plus.
Maybe it is a toss-up????
View paratrooper34's profile
915 posts in 2884 days
#5 posted 02-25-2013 12:56 AM
dpjeansonne, the only way a bench is going to work for you is if you build it to suit YOUR needs. Sure, T-track on workbench tops is unconventional, but if you have a need for that, I say go with it. You could use it in lieu of bench dogs for holding tasks when planing and such. I agree, as mentioned above, if you are going to use the T-tracks to handle bench dog tasks, it has to be securely anchored.
And in the long run, if you find you don’t like that system, the grooves are easily enough filled with strips of wood to match the top.
Good Luck to you!
-- Mike
View bondogaposis's profile
4633 posts in 2283 days
#6 posted 02-25-2013 02:22 PM
What’s easier than drilling holes? I see a couple of disadvantages, first if you put too much downward pressure on the T track you could strip out the screws or deform the t-track. I think the pressure that a vise could generate would be too much for the t track. Second it is going to collect saw dust and sliding fixtures up and down the track is going to be inconvenient if it gets plugged w/ shavings and dust.
-- Bondo Gaposis
#7 posted 02-26-2013 01:42 AM
Your points are very well taken.
I think I am leaning to conventional holes and making jigs or hold-downs that fit the holes.
Thanks for everyone’s input. This is why these sites work so great!
View bpalmer60's profile
11 posts in 2577 days
#8 posted 02-27-2013 02:17 AM
I find that a bench hook really works the best for hand planning and multiple other tasks. Fine Woodworking has several articles and a couple of videos on bench hooks.
-- Bill, Missouri,
View roundguy's profile
62 posts in 2617 days
#9 posted 02-27-2013 02:34 AM
Was looking at these last night… Might have to buy some.
#10 posted 02-27-2013 03:47 PM
I really like those plane stops on Lee Valley.
