Drill press spins in reverse...not a happy camper :(
Forum topic by JSB posted 02-24-2013 03:27 PM 4109 views 0 times favorited 28 replies Add to Favorites Watch
View JSB's profile
JSB
737 posts in 2040 days
02-24-2013 03:27 PM
I finally found a decent used drill press at a decent price yesterday. Tested it one time yesterday with a 1-3/8” forstner bit and it worked fine. I went into the shop this morning and now its spinning in reverse. It takes at least 3 cycles of Off/On to get it to spin correctly. I have never seen this before. I sent the guy an email and have yet to get a response. Not a happy camper this morning :(
Here’s a video of what it’s doing.
-- Jay - http://www.jayscustomcreations.com
28 replies so far
View Monte Pittman's profile (online now)
Monte Pittman
28899 posts in 2300 days
#1 posted 02-24-2013 03:29 PM
Sorry, the motor is going bad.
-- Mother Nature created it, I just assemble it.
View JSB's profile
JSB
#2 posted 02-24-2013 03:30 PM
View Dallas's profile
Dallas
3599 posts in 2449 days
#3 posted 02-24-2013 03:39 PM
Sounds like the start capacitor switch has dust or dirt or gunk on it.
It is meant to close the contacts when the motor stops to let it start again in the right direction.
Clean it and you’ll probably be OK.
View mtenterprises's profile
mtenterprises
933 posts in 2655 days
#4 posted 02-24-2013 04:05 PM
Yup dirty inside. You still have a good drill press even if you have to get another motor.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View JSB's profile
JSB
#5 posted 02-24-2013 04:16 PM
Blew the motor out pretty good. One wire was partially burnt on the capacitor so I soldered it back. Still doing the same thing. I can spin it in the right direction by hand then hit the switch and it runs fine. New capacitor?
Dallas
#6 posted 02-24-2013 04:21 PM
Check the start capacitor Switch.
View JSB's profile
JSB
#7 posted 02-24-2013 04:22 PM
Just opened up the motor. Wire nuts and electrical tape. Looks like it was doctored up to sell.
Dallas
#8 posted 02-24-2013 04:28 PM
What model DP, model of motor, etc.
Get the manual for it online.
If it runs at all, in either direction a little wiring and clean up is not that difficult.
View PurpLev's profile
PurpLev
8534 posts in 3611 days
#9 posted 02-24-2013 04:31 PM
sounds like something is not connected properly. do you have the motor wire diagram (usually printed on the motor/motor cover)? I would check to make sure everything is connected according to where it should.
View JSB's profile
JSB
#10 posted 02-24-2013 04:32 PM
Yeah. I think I need a little more research. Everything seems to check out fine. Excuse my ignorance….by capacitor switch do you mean the main on off switch? I understand household wiring but simply don’t have experience with electric motors. If so the main switch checks out fine.
Dallas
#11 posted 02-24-2013 04:38 PM
The main power from the cord goes into the motor and branches to both the start and the run capacitor.
The run capacitor is energized first to give the motor a burst of energy to start.
There is a switch _after that capacitor that opens, (it is centrifugal) and it opens after the motor starts so the energy goes to the run capacitor.
Hmmm, I don’t like this one, hang on a second while I edit.
Use this one:
View JSB's profile
JSB
#12 posted 02-24-2013 05:16 PM
First off, LumberJocks is awesome. Great community here.
Model # 11-990 (type 1)
Not sure where the capacitor switch is located. Thanks for your patience with me. Here is a short video of what I have so far. Do I need to open up the motor housing?
View JSB's profile
JSB
#13 posted 02-24-2013 05:23 PM
Dallas
#14 posted 02-24-2013 05:30 PM
Yup, I couldn’t find a diagram either, but….
The switch you show is the on/off switch.
The switch you want is inside the motor case.
Follow the Black wires up through the start capacitor and whatever color comes out of the start capacitor.
At the end of one of those wires you’ll find the switch which you seek.
It is “centrifugal” meaning it uses the spin of the motor to open and close.
Other than that, I can’t help much as I don’t get into the motors themselves very much
View JesseTutt's profile
JesseTutt
854 posts in 2073 days
#15 posted 02-24-2013 05:37 PM
Jay, it looks like the motor’s name plate has a motor model number try researching that. If it is the start capacitor switch then you would have to remove the end plates on the motor to get to it. It has been a while since I worked on motors, but I think you only have to take one of the covers off, which one is unknown. Be very careful that you get everything back inside the motor correctly. I would pull the motor off the drill press and work on it at the bench.
Other alturnatives include living with it as you know how to make it spin correctly; replace the motor.
showing 1 through 15 of 28 replies
