Cutting into a late 80's era Uni for dust collection
Forum topic by ScottKaye posted 02-24-2013 02:11 PM 960 views 0 times favorited 9 replies Add to Favorites Watch
View ScottKaye's profile
ScottKaye
656 posts in 2003 days
02-24-2013 02:11 PM
Topic tags/keywords: dust collection unisaw
I recently caught the HF 2hp dust collector on special for $159 so now comes the task of figuring out how to hook it up to my 1987 era Unisaw (34-802 type 1). Since the DC has 4”ports Ive settled on using a matching 4” connector on the lower back of the Uni. My question is.. What is the best/cheapest way to make a circular cut into the side of the Uni’s cabinet.
-- "Nothing happens until you build it"
9 replies so far
5013 posts in 2544 days
#1 posted 02-24-2013 02:23 PM
That may depend on the tools at hand. But the first thing I would consider would be an orbital jig saw with a metal cutting blade. A 4” hole saw would do a much cleaner job (probably) but I would guess most of use don’t have one handy…I know I don’t.
View Brandon's profile
Brandon
4152 posts in 3002 days
#2 posted 02-24-2013 02:42 PM
Does it have to be round? I’m not a dust collection expert but I have seen the four inch table saw hoods that cover a rectangular or square cavity. For example: http://www.rockler.com/product.cfm?page=16972&rrt=1
-- "hold fast to that which is good"
View needshave's profile
needshave
175 posts in 2010 days
#3 posted 02-24-2013 02:47 PM
Good luck with that. I have had my uni since new, it’s an 87, I have attempted several things to effectively pull the dust from the bottom side of the saw, using the door as the entry. (I did not want to cut an unnecessary hole)I have found nothing really very successful other than making a inclined plate in the bottom that allows the dust to fall forward to the entry way where I have a dust port. It works to a degree, but only to a degree. The most effective way to control dust on my Uni was with overhead dust collection on the saw blade guard.
You may want to campaign your concept to others here, maybe it will be fine and I’m doing something all wrong. Which is very possible.
ScottKaye
#4 posted 02-24-2013 02:56 PM
I just checked Home depot, they have a Milwakee 4” bi-metal blade for $20 add another 15-20 for the arbor. Maybe Ill go that route.
Shawn Masterson
1325 posts in 1999 days
#5 posted 02-24-2013 04:39 PM
scottkaye do you mean a hole saw ? without building a shroud around the blade/trunion all you will achieve is to stop accumulation in the bottom. if you go to bill Pentz’s page you will find all the info you will need. even the mods to make the HF DC the best it can be.
http://billpentz.com/woodworking/cyclone/index.cfm
View Wdwerker's profile
Wdwerker
333 posts in 2284 days
#6 posted 02-24-2013 04:51 PM
Great article in Fine Woodworking on adapting tablesaws to dust collection. The key thing I picked up from it was slots for air intake near the motor, blade/arbor and low to direct airflow across the floor and sweep dust to the outlet.
-- Fine Custom Woodwork since 1978
View hairy's profile
hairy
2726 posts in 3583 days
#7 posted 02-26-2013 02:25 PM
Have you seen this? http://lumberjocks.com/topics/32760
Here’s my 89, type 2. I don’t know if that dc is factory or homemade. It was that way when I bought it. It does not function very well.
-- My reality check bounced...
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3209 days
#8 posted 02-26-2013 02:40 PM
Mine’s a type 2 from 1992…here’s my modification built into the motor cover.
-- jay, www.allaboutastro.com
ScottKaye
#9 posted 02-26-2013 03:03 PM
thanks guys for all your input.. love all the ideas..
