I was working on a metal table that was pretty tall and uneven. With a 12” slider, I wanted it bolted down. That metal table has two 3/8” plates welded together on top of it, which used to hold a 125 ton compression strength machine (125 tons of down force, not actual weight of the machine) so drilling holes in that thing would be a chore in itself. So I started this miter station. Its just MDF, screws and glue, but so far it sure beats what I had. Being a rookie, and only having been toying with this hobby for a month or so, I was kind of looking for some suggestions on what to do to it to improve it for storage, and to also learn a little something about joining. I want to try my hand at some box joint drawers with just some plywood. Im not real sure on what to do, but i know i want to do more than just screw and glue the rest of it together.
-- I almost post pics....until I see the daily top three...then I delete my post.
Looks great. I would mount the saw on some t-track so you can slide it forward in those instances when you don’t want the material to engage the wing fences. But it looks like a great start.
-- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed
Good deal, The only thing I would add would be some type of stop block system and maybe a measuring tape either side of the blade. Makes setup much faster and repeatability is essential. Great job on this.
I know that makita guard is a terrible design, but I get jittery when that blade is pointin’ right at me. :& I like the nice wide table for that saw. should be real handy. maybe wax that mdf so i doesn’t swell with the moisture.
I have a table saw, and a little bench top router table. Not having a dado blade will make the table saw operation very tedious, but still doable. Im leaning towards my router table for making them. Ive made a little jig that could be used on either my table saw or my router table with a little modifications.
I have used good old Johnson’s furniture wax for wood. It would work fine in this case. I will also make your wood slide nicely. Not a big deal, but it’s a perk. I don’t know that you need any special joinery for workshop furniture. Still, you might want to consider a shelf, or some drawers for the table. I agree, a stop block system would be really nice. I know it make life a lot easier with the long thin type of wood that you cut on this saw.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
Ive read about coating the MDF in polyurethane, specifically oil based. It works good on everything else, but I bet that MDF would soak it up like a sponge.
Dwain, I just wanted to practice on making good box joints while building some drawers for out here. Maybe by then I would have a better grasp on the process when I actually wanted to use them in a project that went beyond my garage…lol. I have already cut box joints for one drawer today with my router using a home made jig I put together last night and tweaked today. The drawer fits together well, but the wood I cut them out off was some old warped scrap plywood I had. I am satisfied with my jig now though. Ill post some pics of it here in a bit.
8799
224
28
61
82
1538
3556
15818
2040
496
2847
810
903
766
2742
1547
6167
