Used grizzly jointer, good deal?
Forum topic by pendledad posted 02-24-2013 02:57 AM 1643 views 0 times favorited 17 replies Add to Favorites Watch
View pendledad's profile
pendledad
190 posts in 2292 days
02-24-2013 02:57 AM
Topic tags/keywords: jointer
I watched this fall from $175 and I just confirmed $100 if I want it. He did say there is some surface rust on the stand. Thoughts?
Link.
I think it is a g1182 model from comparing to other pictures.
17 replies so far
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2471 days
#1 posted 02-24-2013 02:58 AM
I would buy it for that price if it works
View BorkBob's profile
BorkBob
127 posts in 2895 days
#2 posted 02-24-2013 03:04 AM
You still there? I thought I heard the door slam and a truck start. If you need/want a 6” jointer I don’t see how you can go wrong if it runs. If the tables aren’t true, you can learn to true them. Just check for cracks or stripped bolts. Plan on installing a new belt and maybe blades and you should be good to go. You’re going to want an 8” as soon as you start using it, so getting into it for <$150 total is the way to go. Good luck.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
pendledad
#3 posted 02-24-2013 03:08 AM
I’m torn because this is so cheap, but I like new tools. I was thinking about an 8” new jointer from grizzly.
I would hate to spend $200 after maintenance and time. Would a new one “be” better?
It is tough not jumping on these types of deals. It also kills me because it is less than 3 miles from my house. But I’ve been burnt on used tools in the past.
View camps764's profile
camps764
867 posts in 2563 days
#4 posted 02-24-2013 03:13 AM
for 100 I would have been all over that.
-- Steve
View Everett1's profile
Everett1
213 posts in 2737 days
#5 posted 02-24-2013 03:16 AM
You have to go check it out to see if it’s worth it i say. I’ve got an awesome bandsaw and Drill press from craigs list, i had to make sure to go look at them first though.
Ev
-- Ev in Framingham, MA
View knotscott's profile
knotscott
8150 posts in 3578 days
#6 posted 02-24-2013 03:48 AM
Great deal if it runs. It’s a very well proven jointer….there have been several brands that essentially offered the same jointer from the same factory.
View Bluepine38's profile
Bluepine38
3379 posts in 3288 days
#7 posted 02-24-2013 04:01 AM
Unless you have the money to buy an 8” new jointer, this will be a great addition to your shop, and if you
clean it up and tune it, you should be able to get your money back when you save up enough to buy the
8”. This will be a good user.
View DocSavage45's profile
DocSavage45
8725 posts in 3045 days
#8 posted 02-24-2013 04:19 AM
Go grizzly!
-- Cau Haus Designs, Thomas J. Tieffenbacher
Shawn Masterson
1325 posts in 2151 days
#9 posted 02-24-2013 04:23 AM
go get it you should be able to get more for it than that when you upgrade.
View DMC1903's profile
DMC1903
285 posts in 2530 days
#10 posted 02-24-2013 04:35 AM
I have that same Jointer, it was a gift from my Father inlaw.
After 1000’s numerous bdft of various wood, I have had no issues with it. Just keep the blades sharp, deck clean and waxed.
pendledad
#11 posted 02-24-2013 07:42 PM
So I brought her home, for $100 it is worth a gamble. I want to try out a jointer before I invest $1,000 in a new one. This thing is a bit older than I thought, but it appears to be an early model G1182 6”x47” 1hp. It is made in Taiwan so that is a little different than expected. Everything is pretty gummed up with dust/dirt, so I had some difficulty moving all the parts. But everything appeared to be in good working order. My dad has a sandblasting cabinet, so we’re going to strip the stand and repaint it. It runs pretty smooth, and the knives are old but still cut decently.
The guy I bought it from had the outfeed table lower than the infeed table. I haven’t used a jointer before, but that seems wrong to me. The infeed table should be lower so when the material is moved, it steps up onto the outfeed table to keep it supported. I have to read the manual and be sure I have everything setup right.
I’ll probably get a new v-belt from HF and clean everything up with some steel wool and put a nice coat of paste wax on it.
I’ll also look at how much a new set of knives are. Here are a couple of pictures that show the stand rust. The cord is about 20ft long of what appears to be 12ga wire. Nice bonus. Overall not a bad deal for $100.
View RogerInColorado's profile
RogerInColorado
321 posts in 2157 days
#12 posted 02-24-2013 08:04 PM
Nice score! That will clean up nice. This link is to a site that has great tips for tuning a jointer and solving problems. http://www.newwoodworker.com/jntrprobfxs.html
Enjoy your new toy!
View RVroman's profile
RVroman
163 posts in 2227 days
#13 posted 02-24-2013 08:32 PM
For $100 it is well worth the risk. Iif it works the savings are astronomical. If it does not work then you will have gained an incredible amount of knowledge you can use when caring for and maintaining your $1,000 jointer.
-- Robert --- making toothpicks one 3x3x12 blank at a time!
knotscott
#14 posted 02-24-2013 08:44 PM
That’s a heck of a score for $100. It should clean up nicely. I’ve had an 1182HW since 2001, and it’s been flawless.
View Holbs's profile
Holbs
2008 posts in 2232 days
#15 posted 02-24-2013 08:49 PM
look at my ancient rockwell jointer when i first bought it. worse than yours. now, looks all shiney and pretty. the great thing about a $100 jointer is you can learn how to do maintenance on it. such as, removing the cutter head and knives, sharpening the blades up, etc.
