What to use to notch wood?
Forum topic by Lumpyx posted 02-23-2013 05:51 AM 1433 views 0 times favorited 4 replies Add to Favorites Watch
View Lumpyx's profile
Lumpyx
42 posts in 1793 days
02-23-2013 05:51 AM
I have a piece of 3/8” poplar that’s 5 1/2” x 8”. I need to make two cuts in this board. They will both be on the corners of the 8” side. The pieces I need to notch out are 3/8” x 3/8” and I’m having some difficulty getting this done. Normally I would just dado them out however the saw I will be using at work has a guard that can’t be taken off and the piece is too tall to dado without it hitting the bottom of the guard. What other method is there? I already attempted on my first piece to just mark it out on the board. Score it with a utility knife and follow the grooves with a little six inch hand saw but my lines are so crooked it doesn’t fit snug against the piece it’s suposed too.
-- "For long you live and high you fly, but only if you ride the tide."
View nwbusa's profile
nwbusa
1021 posts in 2155 days
#1 posted 02-23-2013 06:22 AM
Band saw, jig saw, or hand saw. Clean up with chisels if necessary.
-- John, BC, Canada
View Ross's profile
Ross
142 posts in 1841 days
#2 posted 02-23-2013 12:32 PM
Bandsaw. Cut inside the lines and clean it up with a sharp chisel.
-- "Man Plans and God Laughs"
16272 posts in 4087 days
#3 posted 02-23-2013 02:42 PM
If you have a router table, you could do it with a rabbetting bit. You’d want to sandwich it between two waste boards for support.
Lumpyx
#4 posted 02-23-2013 04:31 PM
Thanks guys. I ended up using a table saw in our window repair department that did not have a guard. I just cut a dado with a miter gauge to hold it in place while I cut. I attempted to use the hand saw on my first piece but I have far from a steady hand with that thing.
