| Forum topic by Lee Barker | posted 90 days ago | 391 views | 0 times favorited | 9 replies | ![]() |
90 days ago |
Topic tags/keywords: question How high above the rest of the saw table does the slider sit? I have just installed a Jessem and the specs left it quite high and that doesn’t seem right. Are you a sixteenth or more, or a few thousandths over? Thanks in advance. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
9 replies so far
#1 posted 90 days ago |
Lee, I have not used the Jessem, but that doesn’t sound right to me. I have had two of the Excalibur sliding tables on my Unisaw, and they are fully adjustable for height at the saw and have adjustable legs for leveling it all up. Mine is always slightly lower than the table, and I have a plastic washer on the post that the fence sits on so it clears the table saw table and doesn’t make that awful screeching sound. Don’t know if that helps your situation… -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#2 posted 90 days ago |
I had a Jessem set up an INCA cabinet saw. I had is set |
#3 posted 90 days ago |
I have mine setup about 3/1000 above the saw table. This was the point that the fence glided over the table. BTW, I use this slider all the time. I’ve had it for 5+ years and is still accurate. I do clean the bearings a few times a year. I love it! -- Nicky |
#4 posted 89 days ago |
So far as I know, they should be perfectly level and on the same plane -- "Good artists borrow, great artists steal”…..Picasso |
#5 posted 89 days ago |
I too have the Jessem slider mounted on a General 350; it is perfectly flush with the TS top, which, going by the instructions, is what it should be. Mark -- Tilbilly Mark |
#6 posted 89 days ago |
Yet another wonderful example of the collective wisdom here. Operator error: I did not read to the end of the instructions. Per the text I aligned “the top edge of the mounting bracket slightly more than 3/16” below the top surface of the TS…” That put the finished top of the slider well proud of the TS surface. What I would have learned had I not stopped there is that there are internal ways to raise the surface much more precisely. I feel somewhat stupid but for being a member here. That was a smart move. Thank you for the input. All is well now. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#7 posted 89 days ago |
If it is too high the wood will drop when cut ,or too low fail to sit on the table .So it should be as high as the table. In other words both should be at the same height the sliding table and the standing table. Alistair -- excuse my typing as I have a form of parkinsons disease |
#8 posted 89 days ago |
Within the Felder user community, I believe it’s common to have the slider a few thousands above the table; such that when you clamp work to the slider, it doesn’t drag on the Table. -- Lead By Example; Make a Difference |
#9 posted 89 days ago |
That’s my intuition, MJCD. For it to operate smoothly you’d want the least friction possible on the static table. However, I also don’t want any difference that would affect my sliding waste to the left when I’m ripping with the fence. I think it probably gets down to feel. Thanks again for the healthy exchange of info. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15793 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
