adapting a ryobi bt3100 fence to a Sears 10" table saw.
Forum topic by Bearpaw posted 02-22-2013 07:27 PM 7171 views 0 times favorited 3 replies Add to Favorites Watch
View Bearpaw's profile
Bearpaw
255 posts in 3685 days
02-22-2013 07:27 PM
Topic tags/keywords: tablesaw
I was given the fence from a Ryobi BT 3100 10” table saw.Has any one ever adapted this fence to a Sears 10” table saw. If so, what were the problems?
-- "When we build, let us think we build forever." John Ruskin
3 replies so far
View knotscott's profile
knotscott
7980 posts in 3340 days
#1 posted 02-22-2013 10:31 PM
Sears actually has a version of the BT3100….model 21829, and most of the parts are interchangeable with the Ryobi model. A full size Sears 10” saw is 27” deep….the BT is shorter so you’ll need to take that into account.
View Paul's profile
Paul
11 posts in 1993 days
#2 posted 06-02-2013 12:57 AM
Hey there bear,
I actually just got an old King saw and had the crappy round rail fence. But, I also have a bt3100 with the rail extensions. So what I did was create a new fence out of very hard oak. The dimensions are:
7/8” of net free opening on the handle side and 1 1/8” on the back rail hook. I just made it 7/8” and used a small chisel to snugly fit the back side.
It is also 1 1/4” of net free height from top to bottom.
I also made the rails about 4” tall, but that turned out to be a bit much. That’s ok because it gave me an opportunity to use my jointer plane to flatten them.
I basically cut two 3/4” strips of wood 7/8” wide for the top and bottom. Then, 4” tall faces for the fence.
I then used the swiss cheese angle stock (can’t remember what it’s called right now) of 1 1/2” to drop the rails down. 5/16” bolt are a perfect fit for almost all cast iron table tops. The aftermarket cast iron router table i have is a bit bigger, but that gives my the ability to adjust a little. I elongated some of the holes to allow the fence to go down even further so that they would clear the miter channel.
Works 300% better than the round rails and cost me all of 0 dollars.
If you like the idea, I can send you detailed pics of it to help you out.
Have fun!
Bearpaw
#3 posted 06-02-2013 04:51 AM
Pictures would help. I am about to put the fence in the scrape metal pile. Thanks.
