Plywood thickness on edges of sheets
Forum topic by garberfc posted 02-22-2013 03:26 PM 1264 views 0 times favorited 24 replies Add to Favorites Watch
View garberfc's profile
garberfc
57 posts in 2491 days
02-22-2013 03:26 PM
Topic tags/keywords: plywood thickness question
I’m sure most all users of hardwood plywood realize that the thickness of the material is slightly thinner on the edges. I just have a few questions about it…
In the past if the veneer at the edge was in perfect shape I wouldn’t worry about the thickness and would use the material as is. I liked to take advantage of the perfectly square factory corner.
When using the plywood for cases and sliding the edges into dadoes it’s noticeably tighter / looser based on the board being an edge piece or not. It’s usually not possible to drive a screw threw the opposite side of the dado.
I hope the following questions don’t seem too ridiculousness :-). It’s just the type of thing that keeps me awake at night…
Questions:
  1. Are all four edges thinner or just the long sides?
  2. Are the thin edges milled thinner or do the machines that are handling the boards crushing them? If crushing them, is there any chance of using moisture, steam… to bring the thickness back?
  3. Is the difference in thickness isolated to the veneer, the non-veneer portion or spread proportionally?
  4. On the loose dadoes, should I just use a little extra glue or attempt to make a shim?
Thanks in advance for your thoughts,
F
24 replies so far
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2201 days
#1 posted 02-22-2013 03:51 PM
I never use the factory edge of any sheet good. It is rough, usually damaged, and seldom “perfectly square”.
-- Artisan Woodworks of Texas.... www.awwtx.com
View Grandpa's profile
Grandpa
3261 posts in 2912 days
#2 posted 02-22-2013 04:04 PM
No square corners either. Just luck if there is.
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#3 posted 02-22-2013 04:10 PM
Rip the factory edge and use for back rails, etc.
garberfc
#4 posted 02-22-2013 04:38 PM
What do you feel is the minimum number of inches to rip?
SamuraiSaw
#5 posted 02-22-2013 04:43 PM
Back rails for base cabinets; 1 1/2” is a good size.
Back rails for upper cabinets; At least 2” but not more than 3”
waho6o9
#6 posted 02-22-2013 04:50 PM
+1 for SamuraiSaw
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2309 days
#7 posted 02-22-2013 06:10 PM
I don’t find this to be true on the higher grade plys. i am using a d-3 maple and b-2 and dont have this problem. i routinely use a 3/8” cleanup, and this is euro cabs i am building … mostlt
-- Who is John Galt?
View teejk's profile
teejk
1215 posts in 2921 days
#8 posted 02-22-2013 06:19 PM
I think it all comes out of the factory at a uniform thickness. The edges just get beat-up in every stage of the distribution chain. For what they charge you would think they would treat the stuff like eggs but they don’t, I guess because we usually have no choice other than to “take it or leave it”. I’ve seen some sheets with bootmarks on them.
SamuraiSaw
#9 posted 02-22-2013 06:26 PM
As joey pointed out, this isn’t nearly the issue with better grade sheet goods. The big box stuff is low price point, low grade plywood. Even with the better grade, I don’t rely on the squareness of the panel or the quality of the factory edge for a finished product.
joeyinsouthaustin
#10 posted 02-22-2013 07:15 PM
Samurai And to reenforce your point, even thought the better grade ply has a very consistent thickness, It should not be assumed to be straight, square, or clean (and rarely is) but the thickness is quite consistent, and the tolerances on the others much better. On chinese birch or BBox ply I would routinely take 3” to clean up, as my upper cab nailers are 2 1/2”.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3717 days
#11 posted 02-22-2013 07:46 PM
I agree that cabinet grade ply is much better in uniformity than the big box store construction plywood. If there are thin edges on cabinet ply, its due to the distribution chain as some have said. I always rip off the edge to be sure its square and even before using it. Most times it only takes 1/2 to an inch to clean it up.
-- Wayne - Plymouth MN
View Lumpyx's profile
Lumpyx
42 posts in 2161 days
#12 posted 02-22-2013 07:54 PM
I work in a lumberyard and have never really noticed this before. Im gonna check it out when I go back in from my lunch break here in a bit. I would think it has something to do with how it’s stored. All of our units are banded tightly and sit on two or three 2×4 dryers so the forktruck can get under them. Maybe theres uneven pressure distribution on certain units depending on how they’re built and banded. That’s just a guess though.
-- "For long you live and high you fly, but only if you ride the tide."
View Monte Pittman's profile
Monte Pittman
30138 posts in 2575 days
#13 posted 02-22-2013 08:04 PM
Never trust a lumber yard to cut anything square. That’s not important to them.
Lumpyx
#14 posted 02-22-2013 08:08 PM
That’s not important to some. Alot of the guys I work with dont care at all but I try to cut every piece as if it was my own because I know how frustrating it is to have a board that’s not square.
garberfc
#15 posted 02-22-2013 08:11 PM
@Lumpyx: The difference in thickness is generally < 1/32 of an inch. The difference when using a dado joint is having a snug fit and a joint where the board falls out!
