Drill press tables - how often do you remove yours?
Forum topic by Woodknack posted 02-21-2013 07:03 PM 1826 views 1 time favorited 32 replies Add to Favorites Watch
View Woodknack's profile
Woodknack
12455 posts in 2613 days
02-21-2013 07:03 PM
Topic tags/keywords: drill press drill press table jig
Building one and trying to decide if I should put extra effort into making it easily removable with clamps or just semi-permanently attaching it with screws or lags.
I’m pretty sure I know what I want (fence, replaceable inserts, no t-track) but any feedback on what features you use the most or least (or wish you had) is helpful.
32 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2588 days
#1 posted 02-21-2013 07:06 PM
What you want is a table that is easy to attach different jigs to, this way you don’t have to remove the table, but you can use it for multiple functions.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Ripthorn's profile
Ripthorn
1459 posts in 3218 days
#2 posted 02-21-2013 07:09 PM
I never take mine off, unless doing a lot of metal drilling. Other than that, it stays right where it is.
View PurpLev's profile
PurpLev
8548 posts in 3882 days
#3 posted 02-21-2013 07:10 PM
never took mine off.
View Manitario's profile
Manitario
2702 posts in 3116 days
#4 posted 02-21-2013 07:12 PM
I’ve never removed mine…
View SnowyRiver's profile
SnowyRiver
51457 posts in 3714 days
#5 posted 02-21-2013 07:13 PM
I occasionally take the fence off, but I never take the entire table off.
-- Wayne - Plymouth MN
Woodknack
#6 posted 02-21-2013 07:19 PM
Well that sounds pretty unanimous. I don’t really want to mess with t-track but I will probably want to make some different clamps for it.
View bondogaposis's profile
bondogaposis
5147 posts in 2585 days
#7 posted 02-21-2013 07:21 PM
I can’t recall ever having taken mine off, it’s been years and years.
-- Bondo Gaposis
View OnlyJustME's profile
OnlyJustME
1562 posts in 2610 days
#8 posted 02-21-2013 07:24 PM
Only time i take mine off is when i do metal drilling. Since i made mine from some scrap mdf i don’t want the metal shavings getting embedded in the table scratching my wood projects. One other time was when i needed a little extra depth to fit my piece under the bit. I only have a little bench top DP though so might not be an issue for you.
I used 2 bolts and nuts to secure mine so it’s no big deal to remove or replace.
-- In the end, when your life flashes before your eyes, will you like what you see?
View Chris208's profile
Chris208
240 posts in 2503 days
#9 posted 02-21-2013 07:35 PM
I just built one about a month ago. I havent had reason to take it off yet, but I built mine with toggle clamps underneath that hold the new table to the old table. It works great, and if I do need to take it off,it’s instant. I used the toggle clamps from HF, and they are working great. Very pleased with them.
View paratrooper34's profile
paratrooper34
915 posts in 3185 days
#10 posted 02-21-2013 07:47 PM
Same here, Rick, I put it on and never have removed it. No reason to.
-- Mike
View chrisstef's profile
chrisstef
17795 posts in 3240 days
#11 posted 02-21-2013 08:05 PM
Never have removed mine either. Once in a while it falls off but never purposely. I shoul get around to making it more permanent.
View Don W's profile
Don W
19034 posts in 2801 days
#12 posted 02-21-2013 08:26 PM
View BalloonGuy's profile
BalloonGuy
93 posts in 2156 days
#13 posted 02-21-2013 11:09 PM
I’m with Chris208 – built mine with t-track and toggles as well, and although I haven’t taken it off since building it, it’s no problem to do so.
-- Tom Peterson, Omaha, NE
View Nicky's profile
Nicky
695 posts in 4325 days
#14 posted 02-21-2013 11:20 PM
Mine has 4 bolts holding the table in place. I needed to remove the table a few months back to drill a table leg. Easy enough to remove an put back.
-- Nicky
View nwbusa's profile
nwbusa
1021 posts in 2519 days
#15 posted 02-21-2013 11:29 PM
I’ve never had mine off. I made mine with a drawer which is my favorite feature. I’d like to improve the fence with some type of dust collection, but I haven’t gotten around to it yet.
-- John, BC, Canada
showing 1 through 15 of 32 replies
