how to remove rust
Forum topic by coachmancuso posted 89 days ago 357 views 0 times favorited 7 replies Add to Favorites Watch
View coachmancuso's profile (online now)
coachmancuso
69 posts in 99 days
89 days ago
I got a delta 6 “jointer model # 37-220 in barter for me doing the persons dry cleaning up to 150.00 . I think I got a deal in a half! The machine works great but it has some rust on the table and what is the best way to get it off. Just a little dirty. From what I see on line I think I got a great deal seeing I own a dry cleaners and it will cost me pennies to clean 150.00 of clothing. That was a find!
-- Coach Mancuso
7 replies so far
View JayT's profile (online now)
JayT
540 posts in 379 days
#1 posted 89 days ago
Gray or red Scotch pad, a random orbit or finish sander and some light oil. Used this on my table saw and it worked perfectly without doing anything to the cast iron except cleaning it.
-- "The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself." -- Benjamin Franklin
View CplSteel's profile
CplSteel
140 posts in 332 days
#2 posted 89 days ago
View kdc68's profile
kdc68
851 posts in 445 days
#3 posted 89 days ago
Which ever method you choose to remove the rust, apply a coat of Johnson’s paste wax afterwards. And re-apply as needed. Make it part of your preventative maintenance
-- Measure "at least" twice and cut once
View Richard's profile
Richard
357 posts in 859 days
#4 posted 89 days ago
The Rust Free is good stuff. Smells bad, but sure takes a lot of the work out of rust removal. I give my TS a twice a year treatment with the T-9 and Johnson’s paste wax. Johnson’s is cheap and readily available. Works great.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
View HorizontalMike's profile
HorizontalMike
4930 posts in 1082 days
#5 posted 89 days ago
IMPORTANT! RustFree is good at removing rust BUT DO NOT SPRAY DIRECTLY ON THE METAL! Spray the product on a rage and wipe it on. If you spray directly on the metal you find a permanent splash mark on your jointer that will out live you.
FWIW, I picked up a used jointer on CL maybe 3yr ago and it has this very same type of mark on it and it does NOT come out. Head’s Up!
View Milo's profile
Milo
802 posts in 1487 days
#6 posted 89 days ago
No pictures. Didn’t happen. ;)
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View needshave's profile
needshave
150 posts in 127 days
#7 posted 89 days ago
I just finished cleaning up a jointer as well. I used mineral spirts and wet/dry sandpaper. With the mineral spirts on the table I started with 220 grit wet and dry sandpaper and using full strokes go from one side to the other. I did several times Until I felt no odd surfaces remaining. Cleaned, checked if smooth, followed the same process then went to 240, then 280, then into the 300’s, then 400’s then finally the 600’s. Wiped clean then cleaned with paint thinner. Wiped clean several times then applied three layers of johnson’s past wax. It turned out very nice.
