Let your flatulence fly, scientists urge airplane passengers to LET-R-RIP !
« back to Coffee Lounge forum
Forum topic by Dan'um Style posted 02-20-2013 06:57 PM 1652 views 0 times favorited 7 replies Add to Favorites Watch
View Dan'um Style's profile
Dan'um Style
14171 posts in 3947 days
02-20-2013 06:57 PM
Topic tags/keywords: tip
Let your flatulence fly, scientists urge passengers
Flying increases flatulence, according to an article published Friday in the peer-reviewed New Zealand Medical Journal, and passengers should release the gas—or risk painful medical consequences.
Lead author Dr. Jacob Rosenberg, professor of surgery at the University of Copenhagen, said he always wondered why he had more flatulence flying than when on the ground. Then, after a recent trip, he opened his bag and noticed a water bottle “almost smashed by the change in ambient pressure,” said Rosenberg. “And then I thought of the mechanisms of increased bowel air volume when flying.”
It’s simple. When altitude increases, pressure decreases. According to the thermodynamic principal known as the “ideal gas law,” as pressure drops, volume increases. While cabins are pressurized to compensate, the mechanisms can only do so much. When the plane is at a cruising altitude of 33,000 feet, inside it’s still the equivalent of 8,000 feet above sea level. That’s a lot of physics bearing down on your intestines.
There’s a clear medical rationale for releasing the gas. Holding back flatulence can lead to “discomfort and even pain, bloating, dyspepsia and pyrosis,” according to the article, titled “Flatulence on Airplanes: Just Let it Go,” which surveyed previously published research and studies. It also notes that holding back flatulence has been suggested as a major risk factor for diverticular disease, a condition where pouches develop in the wall of the colon.
But just try telling that to your seatmate.
Instead, Peter Post, a director at Emily Post institute and author of “Essential Manners for Men,” recommends that travelers “hold it in until they have the opportunity to get up and release the gas in the restroom.”
If you can’t get to the lavatory in time, for instance, if there’s turbulence and the fasten seat belt light is on, “be as discreet as possible” and release the gas, said Post. “People understand the situation and let it go.”
Unfortunately, no graceful phrase or gesture exists to completely smooth over the social awkwardness of releasing your personal flatulence inside a confined space where 50 percent of the air is recirculated. An “excuse me” can really only go so far. It can even draw its own unwanted attention.
“Almost anything you say can create embarrassment and make the situation more difficult,” said Post. “Your best bet is to keep your mouth shut.”
The article’s authors suggested airlines install seats embedded with active charcoal, which can absorb intestinal gases. Carriers could also pass out blankets with the odor-absorbing compound sewn in.
Travelers could also be subjected to a methane breath screening and those with higher methane content could be assigned seats in a restricted area of the plane near the lavatory. Another proposed solution involved the use of rubber pants with air containers to collect passed gas.
As for passengers, they could wear underwear lined with active charcoal, the article said.
Rosenberg said that though the paper had “a humorous direction,” it’s based on published research. “The background is serious,” he said.
But fliers prone to gas should take preventative measures. Post suggests Beano.
7 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3122 days
#1 posted 02-20-2013 07:08 PM
Terrorist propaganda.
-- jay, www.allaboutastro.com
16274 posts in 4182 days
#2 posted 02-20-2013 07:17 PM
Thank God they don’t allow lighters on airplanes any more!
404 - Not Found
2544 posts in 2933 days
#3 posted 02-20-2013 08:30 PM
Rubber pants with air containers are the future.
View DrDirt's profile
DrDirt
4423 posts in 3706 days
#4 posted 02-20-2013 09:14 PM
This is why they are so adamant about not smoking or tampering with the smoke detectors in the lavatories!
Dan'um Style
#5 posted 02-21-2013 12:29 AM
View JollyGreen67's profile
JollyGreen67
1661 posts in 2727 days
#6 posted 02-21-2013 01:48 AM
Hip waders and duct tape – ala Red Green !
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View Dusty56's profile
Dusty56
11819 posts in 3652 days
#7 posted 02-21-2013 02:15 AM
Thanks for the latest gas news , Dan….FOL : )
