Forstner Bit Problems! WHY????
« back to Woodturning forum
Forum topic by AnthonyD posted 93 days ago 554 views 0 times favorited 12 replies Add to Favorites Watch
View AnthonyD's profile
AnthonyD
20 posts in 103 days
93 days ago
Topic tags/keywords: question drill-driver lathe turning milling woodburning shaker
So Im making some salt and pepper shakers and grinders. Theyre coming out nice but when I drill out the center with my forstner on the lathe, they smoke and burn the wood pretty badly. No matter how slow I go, it keeps burning up. I cant figure out why. They arent cheap bits. Theyre not the best but they arent bad. Maybe I need to buy better ones? Doesnt anyone know what I can do or at least why this keeps happening??
PS. I am New to LJ and I just have to say that the people on this site are just amazing. Every forum topic I post is mostly about troubles that I run into and everyone is just soooo helpful. Thank you to everyone who gives me thair advise, and those who comment on my projects.
-- AJ DeSantis
12 replies so far
View RussellAP's profile
RussellAP
2394 posts in 458 days
#1 posted 93 days ago
Maybe you need a larger pilot hole.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
RussellAP
#2 posted 93 days ago
What wood are you using? How fast is the lathe turning? Is it turning the right direction?
View Mosquito's profile
Mosquito
2800 posts in 464 days
#3 posted 93 days ago
I don’t have any experiences with the lathe aspect, but I’m not sure slower feed rate is the answer (if that’s what you meant by slower). In fact, it’s probably the opposite when using the lathe.
What’s the RPM of the lathe you’re trying to use, and size of forstner bit?
This can be a useful chart for recommended drilling speed (RPM) for various bits for hard or soft wood.
http://www.fnal.gov/pub/takefive/pdfs/Drill_Press_Speed_Chart.pdf
Hope that can help a little.
-- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods
View lew's profile
lew
8989 posts in 1927 days
#4 posted 93 days ago
Even new Forstner bits will burn in most hard wood, especially the larger diameter bits. Not sure what your lathe slowest speed setting can be but a couple of hundred RPMs is about as fast as you want to go, if possible.
Also, you are probably boring into end grain- which compounds the problem. Extracting the chips often can help some. The only other thing I can think might be happening is that the wooden blank and the bit are not coplanar. That is the center line of the blank and the center line of the bit may be at a slight angle. This would make one side of the bit rub more as it cuts thru the wood..
On the positive side, it’s on the inside and out of site.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Phil53's profile
Phil53
68 posts in 1794 days
#5 posted 93 days ago
I still consider myself a beginner but here are some of the things I have run into.
Make sure your bit is sharp and clean. Just because it is new does not mean that it is sharp.
Looks like you a cutting into end grain and that is tuff on any bit.
Also play with you speed a little that will make a diffrence.
Have fun…
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1330 days
#6 posted 93 days ago
I bored out the end grain in regular 2×4s using a 3/4” forstner bit the other day. It took considerable muscle to do that job, but I didn’t get any tear out. This is a tough task with hardwood. You will need very slow speeds and considerable boring pressure with a larger forstner bit in order to limit the burning. I’m not sure how that works on a lathe (explain please), but I’d also considering pre-boring most of the waste with a conventional bit or even a hole saw. You can then take a finish cut with the forstner bit, requiring less boring pressure to make the cut.
I’d consider drilling out the holes on a drill press.
-- jay, www.allaboutastro.com
RussellAP
#7 posted 93 days ago
It might profit you in future projects to use a system of stepping up from a 3/8 hole with progressively larger bits until you get the right diameter. Then you can turn the hole to fit the stopper.
View jeff's profile
jeff
425 posts in 1637 days
#8 posted 93 days ago
I agree with RussellAP…I recently attended a class on how to make a peppermill at our local Woodcraft store and i used two forstner bits to drill out the hole for the peppermill and my wood choice was mesquite-which is pretty hard wood…
-- Jeff,Tucson,Az.
View Monte Pittman's profile
Monte Pittman
7078 posts in 510 days
#9 posted 93 days ago
When I was drilling mine I was drilling into the end grain. I was amazed how fast it dulled my Forster bits. Then it drilled hard slow and burned. That would be my guess.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View bondogaposis's profile
bondogaposis
1254 posts in 523 days
#10 posted 93 days ago
Slow down the speed and increase the feed rate. Also back out frequently to clear the chips.
-- Bondo Gaposis
View PurpLev's profile
PurpLev
7764 posts in 1820 days
#11 posted 93 days ago
step up to your final hole. since you are on the lathe, the alignment is automatically set for you by the machine, so you don’t need to drill the final size hole with the actual bit using the brad in the center to keep it centered.
1. start with a smaller forstner, and use a larger one in each boring operation until you reach your final size.
2. don’t slow the lathe too much or you’ll get poor cut quality and/or a chance for the bit to snag and split the wood. practice makes perfect.
3. don’t feed too slow or you’ll smoke the wood/bit with too much ongoing friction between the 2. feed in, and pull bit out to clear chips – rinse and repeat.
View RogerInColorado's profile
RogerInColorado
206 posts in 126 days
#12 posted 93 days ago
When the bit gets hot to the touch, let it cool before you proceed. Big friction generates lots of head, especially in larger bits. Problem is compounded in end grain.
