| Forum topic by RusticElements | posted 75 days ago | 318 views | 0 times favorited | 15 replies | ![]() |
75 days ago |
Topic tags/keywords: question pine tablesaw joining I purchased a new dado set so I could work on my beehive project. So far I’ve only made enough box joints with the set to make 6 hives and it is so dull it’s almost unusable. Is this normal? It’s a $100 Diablo set cutting pine. -- Michael R. Harvey - Brewster, NY - RusticElementArt.com - SpaceAware.org - AnConn.com |
75 days ago |
Cutting pine, the first thing I would check for is pitch on the blades. I would take them off and clean them. You can buy a chemical spray to clean pitch off of blades. It burns my skin. I use WD-40, let it soak and if it needs it I brush it a little with a brass bristle brush. Cleans stuff right up. Wipe it off, reinstall it and you should be good to go. -- Berta in NC |
75 days ago |
Ditto on Steelmum’s comment. I bought the Rockler blade cleaning kit but have yet to use it. It was on sale recently for about 18 bucks. I hear it works well. -- Tony, Ohio |
75 days ago |
Michael, some use oven cleaner. I have heard it works well. -- Grumpy - "Always look on the bright side of life"- Monty Python |
75 days ago |
I use both the Rockler product and oven cleaner. Both work well. I tend to like the oven cleaner better since I just spray it on and put the blade outside for 10 to 15 minutes (a good excuse to spend some time in the shop) and rinse it off. Dry the blade with shop towels. But to answer your question I don’t believe that the dado set should be dull yet. I have a Forrest dado set that I bought 5 years ago and it is still sharp despite a lot of use since I do all my rabbeting and dadoing on the ts. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
75 days ago |
Do you have the blades in the setup running the right way? Bob -- A mind, like a home, is furnished by its owner |
75 days ago |
Something else is wrong here, that’s really not enough cutting to get pitch build up unless you’re using green wood. This may sound idiotic but check to make sure the blade is mounted so the blade is rotating in the proper direction. I made the mistake of putting a wobble dado (not a word about my wobble dado LJ’s) on with the teeth facing the wrong direction. Got alot of burning and difficult cutting to say the least. IF there is visible pitch build up there are any number of products to remove it. Cheap alternative is denatured alcohol or acetone. Steel mum is right wrap in paper towels and let is soak and use a brass brush. -- DocK, WV |
75 days ago |
Ah yes now I see Bob’s post must have come in while I was typing. Glad I wasn’t the only one who has done this -- DocK, WV |
74 days ago |
If the blades are the right way and the blades are clean, it is possible that the blades are dull. This can happen if you’re trying to cut too deeply and your tablesaw doesn’t have the power to support the cut. Did you get a lot of burning? The heat will make the blades dull more quickly. |
74 days ago |
I too installed backwards when making a zero clearance insert. couldn’t figure out the smoke at first. Apparently this is a more common mistake than it should be! lol |
74 days ago |
Also make sure the outside blades are mounted properly, I had a couple of projects where the bottom edges of my dados had ramps. If you are cutting through real pitchy material see above about cleaning but I like to use Krud Kutter, you can get it a the orange Box. Make sure that no matter what you use you give it a good rinse with water an dry it (I like to use my airhose. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
74 days ago |
Just to add to the pitch cleaning effort, I’ve also heard Simple Green works well to remove pitch from saw blades and router bits. -- "The only thing that counts is faith, expressing itself in love." --Galatians 5:6 |
73 days ago |
Thanks for all the info guys. But do you think I’m dumb enough to put the blades on backwards? Well, OK, I am dumb enough. I did it a couple weeks ago. Took me a while to figure out why it was cutting poorly and making a lot of smoke. Unfortunately, that wasn’t the case this time. After last time (I do learn sometimes ;)), that was the first thing I checked. I used acetone and a brass brush, because that’s what I happened to have on hand. Made a big difference. Not like new, but much better. -- Michael R. Harvey - Brewster, NY - RusticElementArt.com - SpaceAware.org - AnConn.com |
73 days ago |
I use any of those orange cleaners. Cheap, safe and it works. -- Darell, Norman, Ok. |
61 days ago |
I agree with Darell. Orange oil works, its “green” and you can pour the remnants over fire ant mounds! -- North Texas |
61 days ago |
I’ve been using Krud Kutter to clean my blades. It’s a liquid concentrate used with pressure washers. Just a couple of caps full with some hot water and let the blades soak for a few hours. Brush off with a nylon brush, rinse and they’re like new. -- Make things with wood. |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
123 |
| Become a sponsor |
378 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
