Joinery problem
Forum topic by Mark posted 94 days ago 534 views 0 times favorited 18 replies Add to Favorites Watch
View Mark's profile
Mark
136 posts in 147 days
94 days ago
I’m making a bunch on mortise and tenon joints for a project I’m working on. While most of the joint aren’t bad there are 3 or 4 where the tenon will just slip into the mortise with no friction at all ( they don’t rattle around, it’s just not snug). While I don’t want have to beat the two together I don’t really want sloppy joints either. Is there something I can do to tighten these up a bit? Thank you.
-- Mark
18 replies so far
View felkadelic's profile
felkadelic
156 posts in 712 days
#1 posted 94 days ago
You could probably glue a thin piece onto the tenon cheek, and plane it down until you get a proper fit. Pay attention to matching the grain direction.
View TCCcabinetmaker's profile
TCCcabinetmaker
743 posts in 527 days
#2 posted 94 days ago
If what felkdelic says does not work, then you could also try a product called woodswell. It’s mostly used to repair old furniture mortise and tennon joints, I know it’s usually available from ace hardware stores, but not all of them will carry it.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Howie's profile
Howie
2449 posts in 1095 days
#3 posted 94 days ago
Wrap the tenon with a piece of masking tape if the gap isn’t too big.
-- Don't rollerskate in a buffalo herd
View ksSlim's profile
ksSlim
803 posts in 1062 days
#4 posted 94 days ago
Brown shipping paper makes excellent shims on some of my tenons.
Glue to one side or wrap completly around as necessary.
-- Sawdust and shavings are therapeutic
View Cosmicsniper's profile
Cosmicsniper
2150 posts in 1331 days
#5 posted 94 days ago
I usually glue another piece on, matching long grain…then re-cut. Happens all the time. Nice thing about non-through tenons it that nobody will ever know.
-- jay, www.allaboutastro.com
View Holbs's profile
Holbs
216 posts in 202 days
#6 posted 94 days ago
slim: brown shipper paper. now that’s a good idea! i’ll jot that one down.
mark: if worse came to worse, you could go floating tenons.
View rockindavan's profile
rockindavan
254 posts in 808 days
#7 posted 94 days ago
I would agree glueing a shim is the best way. With that said, I worked in a shop in college with a lot of new woodworkers. Needless to say there were more loose tenons then good or even decent fitting tenons. Most of them used epoxy to do their glue ups. It works and should hold fine, but is more or less the quick and dirty way.
View Mark's profile
Mark
#8 posted 94 days ago
As always. Thanks for all the great tips. Depending on the gap, and it ain’t much, I’ll probably try both.
-- Mark
View LeChuck's profile
LeChuck
344 posts in 1235 days
#9 posted 94 days ago
If it’s slipping down easily but without slop (no gaps), a lot of glue will probably work just fine :) That’s what happened on my workbench base build and hand cut mortises. I used Titebond 3. Some were really tight, others went in easily. You can alos peg and/or drawbore them.
-- David - Tucson, AZ
View tsdahc's profile
tsdahc
69 posts in 524 days
#10 posted 94 days ago
On my bench build I am doing my mortises were less than perfect, I drawbore them and they are solid as a rock now, no play what so ever. Between the glue and the drawbore they should be very strong
View Lee Barker's profile
Lee Barker
1889 posts in 1023 days
#11 posted 94 days ago
If the tenon slips in but doesn’t rattle, I think you’re fine. Here’s why: When you add, say, yellow glue, the inherent moisture does two things: It slightly increases the size of the tenon and, conversely, or similarly, it reduces the size of the mortise. Would it be too Pollyanna to think that, then, the room for the glue would be “Just right”?
If you’re still set up, would you be willing to make a few extra and try some of these ideas? There are several here that sound pretty good.
My least favorites would be masking tape (it’s foreign to the adhesive I am assuming you are using) and the woodswell stuff, which eventually fails.
Kindly,
View dbray45's profile
dbray45
2018 posts in 949 days
#12 posted 94 days ago
I have two ideas for you if you want a permenant solution – modify as you will -
Using the same type of wood, shave off some paper thin cuts. use these as shims – keep the grain going the same as the tenon, add glue and insert into the mortice.
If the sloppiness is back and forth but up an down is tight, using a thin kerfed saw or bandsaw blade and cut a slice in the tenon 3/4 up the middle in the same direction as the sloppiness. Make a wedge that is just a little thicker than the width of the cut and a little shorter than the slice. Put the wedge into the slice just enough to hold the wedge, glue evrything and insert the tenon and wedge into the cleaned out mortice. Tap home with a deadblow hammer. As you tap the tenon home, the wedge expands the tenon inside the joint. If the wedge is to wide, you split the joint so measure carefully. If the mortice is not carefully cleaned out, you will not drive the tenon all the way down, if the tenon does not touch the bottom of the mortice, make the wedge a little longer.
Once this joint is together, there is no adjustment without a saw and morticing chisels.
-- David in Damascus, MD
View joeyinsouthaustin's profile
joeyinsouthaustin
519 posts in 245 days
#13 posted 94 days ago
At some time I have used all of the above (except masking tape, sorry Howie)
I have also resorted to Gorilla Glue (the original) in some of my loose tenon errs. It foams up and fills any gap, looseness, and bonds tight. I use a dam of masking tape around the joint, after it is made to keep it from being a big mess. Don’t add a lot of water, or you can end up with the wood swell failure Lee Barker points out.
My 2 cents.
-- Who is John Galt?
View Mark's profile
Mark
#14 posted 93 days ago
Wow! Nothjin’ like experience when it’s talkin’. Thanks again all.
-- Mark
View Loren's profile
4901 posts in 1820 days
#15 posted 93 days ago
With machine cutting of tenons there are 2 basic
ways to do it:
1. the easy way, one the flat on a table saw. This
results in tenon thickness issues.
2. the not-so-easy way in which you use 1 reference
face instead of flipping the work.
