Resawing Blades
« back to LumberJocks.com Site Feedback forum
Forum topic by Handtooler posted 89 days ago 408 views 0 times favorited 11 replies Add to Favorites Watch
View Handtooler's profile
Handtooler
389 posts in 299 days
89 days ago
Topic tags/keywords: question
LJ’s I own a Craftsman 12” band saw which I have learned recently to set up and adjust to achieve super cuts, and have re sawn some 3-4” wide boards to less than 1/4” veener strips; however, I am interested in acquiring a better blade than my current Olsen 3TPI 1/2” blade. The Wood Slicer has been recommended in several previous forum entries, but it comes in 801/2” length not 80” as my saw requires. Might I expect to be able to achieve the necessary tension to properly resaw with it. I’ve used a 5/8” blade sucessfully in the past even though the manuual says not to exceed 1/2”. The Chattanooga company that used to weld blades for me from bulk stock is no longer in business.
-- Russell Pitner Hixson, TN 37343 bassboy40@msn.com
11 replies so far
View JesseTutt's profile
JesseTutt
707 posts in 277 days
#1 posted 89 days ago
Try the Timber Wolf They list a 1/2 inch by 80 inch. I think they will custom weld any lenght you need.
View MaroonGoon's profile
MaroonGoon
88 posts in 125 days
#2 posted 89 days ago
We are in the exact same situation! We must have the same 12” Craftsman band saw because this past weekend I was looking online for a Wood Slicer blade and my saw requires an 80” blade also. I will look forward to someone giving an answer to this :)
-- "Only put off until tomorrow what you are willing to die having left undone." -- Pablo Picasso
Handtooler
#3 posted 89 days ago
Thanks Jesse! I’ve also read several very fine reviews for the Timber Wolf blades.
View Don W's profile
Don W
9939 posts in 734 days
#4 posted 89 days ago
Take a piece of string, 80” long and see if your saw will tighten that much. Actually, tighten it all the way and measure. I’d be surprised if 1/2” would make that much difference. Both my bandsaw have a couple inch travel.
View lumberjoe's profile
lumberjoe
2396 posts in 415 days
#5 posted 89 days ago
You can get an 80” timberwolf. I hear great things about those blades
-- http://www.etsy.com/shop/KandJWoodCrafts
View Surfside's profile
Surfside
2277 posts in 340 days
#6 posted 89 days ago
1/2” – 3/4” with 3-4 TPI bandsaw blades are recommended for resawing. Timberwolf has 80” or 6’8” length.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View David Kirtley's profile
David Kirtley
1250 posts in 1165 days
#7 posted 89 days ago
Suffolk Machinery that makes the Timberwolf will make them whatever length you desire. They don’t charge extra for it.
View SCOTSMAN's profile
SCOTSMAN
4308 posts in 1752 days
#8 posted 89 days ago
Your bandsaw unless it is very poorly designed should be able to accept an extra half inch without too much problem.IMHO I really cannot see this as a problem ask the manufacturer to be safe but I would not let a small deviation of that amount worry me.There should be more room to tension than a half an inch. see what others say.Alistair
Handtooler
#9 posted 89 days ago
I am also to understand that Timber Wolf badese do not require as much tension as other manufacturer’s; is this so?
View Gene Howe's profile
Gene Howe
3186 posts in 1595 days
#10 posted 89 days ago
Russell,
I believe you are correct, but I’ve always tensioned them to the same “note” as other 1/2”s, I’ve used. But they’ll make them to your specified length.
Handtooler
#11 posted 89 days ago
Thanks all for your kind information.
