| Forum topic by Roadmaster | posted 88 days ago | 668 views | 0 times favorited | 19 replies | ![]() |
88 days ago |
Topic tags/keywords: tablesaw question dust redheart vacuum Hello, everyone. I’m fairly new here, though I read a lot of forum topics before I ever joined LJ. I just have a small wood shop in my garage, with a few decent tools. The way I manage dust collection is with a 20 gallon Craftsman wet-dry vac. I’ve been working with different hardwoods, and really having fun experimenting with species unknown to me. The last couple of projects I’ve made have used mahogany, purpleheart and spalted tamarind. (I made sure to wear a painter’s mask working with the spalted wood). My latest experiment is working with chakte kok (redheart). I love the color of the wood, and since the final product is going to be used indoors only, I’m hoping with some kind of UV-blocking urethane it’ll stay that way. But color preservation isn’t my issue right now. My issue is the dust. The wet-dry vac has been great so far, but working this redheart is like an aerosol can spraying red chalk. The vacuum doesn’t seem to be doing any good at all. The dust is everywhere… on the table saw where the hose is connected, coating the vacuum, covering the floor and hanging in the air. I’m thinking that I should buy a HEPA filter (#17912) for it, and perhaps that will do the trick. Does anyone else have a similar experience? I’m also thinking I should get a proper respirator. Thanks in advance, |
19 replies so far
#1 posted 88 days ago |
I am in the process of converting my shop vacs for better dust control. Getting a HEPA filter alone will help, however it is only the first step. You also need to get the micro-filter bag. These are much better and trap 95% of the .5 micron dust. Then I am putting a dust deputy in front of the vac. The dust deputy will collect a considerable amount of dust before it gets to the vac. The dust deputy is usually installed on a 5 gallon bucket. You need a very good seal for the dust deputy. The optimal solution would be to get a Festool Dust extractor (which is not in my budget at this time) and it has additional features such as automatic on when the tool is powered. It also has variable speed, which I will add to my system via router speed control. The HEPA filter I got from HD for $20, the bags I had to order on line for $17 for two, and the Dust Deputy I got from Woodcraft for $40. This won’t be a commercial off the shelt dust extractor, but much better than a off the shelf shop vac. -- Bill R |
#2 posted 88 days ago |
If you’re going to have that big a mess, you should build with padauk. At least it smells nice. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#3 posted 88 days ago |
Sounds like the dust is being thrown at you from the blade. An overhead blade guard with a dust collection port connected to the riving knife will capture most of it, but then you need a proper dust extractor to attach to the guard and dust port behind the blade. I just don’t think a shop vac on its own is sufficient. Buy a decent respirator while you’re thinking about it. -- Do or do not, there is no try |
#4 posted 88 days ago |
Get the respirator. Certain woods are worse than others. However the more fine of dust it produces the more potential health problems it can cause. I do a lot of work with aromatic red cedar. Its dust causes asthma in humans and asthmatic reactions in those who already have asthma. We laugh about sawdust in the nose, it is a hazard. A good dust mask is essential. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#5 posted 88 days ago |
I wish that I had taken more precautions in the early years of my career. It’s very important to protect your lungs and nose. You should read up on the worst offenders when it comes to wood. When it comes to the most problematic wood perhaps you should stay away from them until you have better dust collection. helluvawreck aka Charles -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#6 posted 88 days ago |
It sounds like you need an ambient air filter. -- Bondo Gaposis |
#7 posted 88 days ago |
It seems like no matter how much dust collection you have dust will get everywhere. Dust lands everywhere with most all woods but it is just more noticable with home highly colored woods such as Padauk. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#8 posted 87 days ago |
i second the dust deputy .i have two and one home made cyclone for my vacs . they are major time and hassle savers – you are not constantly plugging vac up .your find you will get more done if your not constantly cleaning up .and some tools work better with out chips and dust .like a router table ,chips are not in the way .Sanding also.goes faster and paper last longer . |
#9 posted 86 days ago |
Redheart, Bloodwood, spanish cedar and especially MDF all fine dust coat everything badly. It clogs the filters of air cleaners and dust collection at the source seldom grabs it all. Use your respirator and try to catch as much as possible and filter the returned air to your shop. I guess I have resigned myself to this, and learned to live with the mess, cleaning more often. All fine grained wood and manmades do this but the colored or light woods just look more obvious. Ebony, blackwood, panga panga/wengee are very noticable too. -- Improvidus, Apto quod Victum-- Improvise, Adapt, Overcome |
#10 posted 86 days ago |
Thanks so much for all the helpful replies! I had never heard of a Dust Deputy before, but after reading reviews and watching videos, I was convinced. I bought one last night, and tonight I’m going to build a little frame to join it to my Craftsman wet/dry vacuum. I also bought a HEPA filter for the vacuum – and realized I had a pretty substandard filter when I put the new one on. The claims of asthma were pretty scary, so I ordered a 3M 7500 respirator with P100 filters. Breathing is no joke. I’ll update here once I get it all in place. Thanks again! |
#11 posted 86 days ago |
You will love the Dust Deputy. I have one on a shop vac. The shop vac basically stays clean and empty. |
#12 posted 67 days ago |
As predicted, the Dust Deputy is fantastic. Now then, what does one do with five gallons of mixed-species sawdust? There must be something productive to do with it.
#13 posted 67 days ago |
Be careful with the dust. We have many folks who want our dust for composting, animal bedding and others. But the same reason it is bad for your lungs can make it bad for many other applications. If you have free time, research paper making. -- Who is John Galt? |
#14 posted 67 days ago |
That worked great. If it’s pure sawdust with no finishes or other contaminants, it’s great for compost. Mix it yourself about 50/50 with nitrogen rich material like fruit and vegetable scraps or grass clippings. Or find a local gardener that wants it. Needs to be moist for compost so that’s one use that solves most of the lung issue since it won’t fly into the air when wet. |
#15 posted 67 days ago |
RussellAP is right about padauk! -- "I never met a board I didn't like!" |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2027 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
