Bandsaw Purchase
Forum topic by Richard posted 02-18-2013 10:20 PM 1566 views 0 times favorited 12 replies Add to Favorites Watch
View Richard's profile
Richard
400 posts in 2719 days
02-18-2013 10:20 PM
Topic tags/keywords: bandsaw
I’ve been sizing up bandsaws, reading nearly everything I can find about 14 inch saws.
Some limiting factors – I only have 110/20 amp service in my garage and upgrading to 220/30 amp is a nice idea, but not an option in the short run. If and when I have a new garage built, it will be without question part of the build.
Price – $1000 hard ceiling. That includes accessories, blades, mobile bases, etc. No Shipping! No Shipping! No Shipping! Did I mention No Shipping? Shipping charges will inflate the final price paid and I have worked with shipping companies enough to know that it’s a roll of the dice. Lot’s of negative reviews of tools start out complaining about shipping damage. No thanks, I have enough aggravation in my life.
I am determined to buy locally, where I can get eyeball to eyeball with the seller if issues arise.
I have narrowed it down to a couple of contenders.
In order of preference:
Shop Fox W1706 – Available locally for $549+tax. I have seen the machine demo’d. Reviews are in somewhat short supply. The seller also does warranty work for Shop Fox which I consider a huge plus. I know Shop Fox and Grizzly are essentially the same, but Grizzly is not under consideration because of shipping.
Rikon 10-320 – not available locally, the local Woodcraft can order it with their regular shipment, but needs a two week lead time. $649+tax. No shipping costs. I have not seen it demo’d, but there are tons of reviews of the saw, mostly favorable. I know the Craftsman BAS350 is essentially the same saw, but by the time I buy the Rikon fence for it I haven’t saved much. And I am suspicious about what other cost cutting measures Sears may have forced on Rikon for the BAS350.
Rikon 10-325 – nice saw, but at $929+tax exceeds my $1000 limit, so it is not in play.
I am not looking for alternatives to the two saws, my mind is pretty well made up that I will buy one of the two in the next 24 hours. But would like to hear opinions for or against either one.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
12 replies so far
View Dallas's profile
Dallas
3599 posts in 2514 days
#1 posted 02-18-2013 10:31 PM
Flip a coin, Rikon = Heads, Shop Fox = Tails.
If you don’t like the outcome, you know which one you want.
View Surfside's profile
Surfside
3389 posts in 2201 days
#2 posted 02-18-2013 10:38 PM
Shop Fox W1706 has few good feedback. Rikon 10-320 has many positive reviews. Both have 2 year warranty and expensive saws.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View toolie's profile
toolie
2134 posts in 2656 days
#3 posted 02-18-2013 10:51 PM
too bad about that 24 hr deadline. the 10-325 usually goes on sale at least twice a year at woodcraft. last christmas, it was $799 with a $100 gift card for blades and accessories. ruling out the bas350, which is a derivative of the 22401, is a dicey decision. they are both like the 10-320, only the bas350 is $200+ less. i bought and sold two 22401s when sears discontinued them. that was a REALLY sweat unit. more features and power than a 10-320 at a lower price.
given your two stated choices, the SF is my choice for its features. also, it has a tension release feature. the 10-320 doesn’t. and with the upper blade mechanisms inside the upper wheel cabinet, there’s no way to retrofit a release to the 10-320.
View bullhead1's profile
bullhead1
228 posts in 2276 days
#4 posted 02-18-2013 11:07 PM
I have the Shop Fox 1706 for a year now and have had no issues. I have resawed 4×6’s with it and cut curves as well (of course with different blades). The users manual is excellant and I have no problems changing blades and making needed adjustments. It is convertible from 110 to 220 which I will do shortly as I’m installing 220 to support the Shop Fox table saw that I’m getting later this week. I got mine at a local supplier for the same reason you are looking local instead of worrying about the shipping issues and service. My local supplier has a woodworking show every year and Shop Fox offers 10% off plus they set it up and tune it. I’m sure the Rickon is a nice saw so I can’t speak to it. If you want to add a riser block you can get one from Grizzly but I haven’t yet as I don’t have a need for it. Good luck.
View ShaneA's profile
ShaneA
6956 posts in 2626 days
#5 posted 02-18-2013 11:09 PM
Call the closest WC and see f they can swing the 10-325 for $799, or wait till March 1st, looks like all power tools will be 10% off that weekend. Worth it to wait hair longer…good luck.
View bladedust's profile
bladedust
206 posts in 2293 days
#6 posted 02-18-2013 11:18 PM
Just in case you change your mind about shipping, Highland has the 10-325 on sale for $799.
http://www.highlandwoodworking.com/rikon-14-deluxe-bandsaw.aspx
http://www.highlandwoodworking.com/blasts2012/rikonsale.html
-- ok, is it cut once measure twice, cut twice measure once???? I know....I'll just keep cutting until it's long enough.
View paratrooper34's profile
paratrooper34
915 posts in 2979 days
#7 posted 02-18-2013 11:22 PM
Richard, I bought the below Craftsman band saw on Friday. It is a nice piece of machinery. I bought a good 5/8” blade and used it a bunch this past weekend making a nightstand. I resawed a 7 1/4” wide piece of pine and a 6” piece of maple. It was easy to set up and once I got it there, it cuts straight with no issues. I got an additional 1/4” blade, a magnetic fence, and a mobile base and all totaled it came to just over $700. Great value and wirth the money. LumberJoe did a write up on it so you can research it’s performance from him also.
http://www.sears.com/craftsman-14-inch-band-saw/p-00932607000P?prdNo=2&blockNo=2&blockType=G2
-- Mike
View Mosquito's profile
Mosquito
9355 posts in 2319 days
#8 posted 02-19-2013 12:18 AM
Menards also has the Rikon for the same price, free ship-to store, but also 2-3 week lead time. Don’t think that’d qualify for one of their 11% off sales, though…
I also looked at some Rikon tools before, and I liked that Rikon didn’t seem to be cheaply made, but instead took a “no frills” approach.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
Shawn Masterson
1325 posts in 1976 days
#9 posted 02-19-2013 12:43 AM
just a thought the HF 14” is a pretty nice saw and a lot cheaper. do a search a lot of people really like them, I do.
really what’s in a BS a motor, bearings, wheels, tires , and a name. so why not save some money on a name and use the $ for upgrades
View unisaw's profile
unisaw
92 posts in 4160 days
#10 posted 02-19-2013 04:27 PM
I just took delivery (30 minutes ago) of the 10-325 from Amazon at $1,024 with Prime no-shipping. I took the no-frills years ago with a 3/4 HP Grizzly and regretted it from day 1. Gave it away to a shelter workshop. I do like my Grizzly TS and Jointer. I won’t buy a Craftsman based on my experience with some of their other tools – could be wrong but burn me once shame on you, burn me twice… The 325 offers 1.5HP, beefier blade guide system, viewing window and other frills.
View Marcus's profile
Marcus
1163 posts in 2047 days
#11 posted 02-19-2013 04:30 PM
Woodcraft is having 10% off their power tools the 1st and 2nd of March, so you could get the 10-325 under your price ceiling then. They’ll let you order it now so its in their store on the 1st for pick up.
View gtbuzz's profile
gtbuzz
427 posts in 2469 days
#12 posted 02-19-2013 04:35 PM
I’d wait a little while if you could and try to get the 10-325. It may be $949 right now, but it seems to go on sale at Woodcraft a few times a year for $749 to $799. It’s the exact same footprint as the 10-320 and you get the extra resaw capacity and extra half a horse. In the long run, I’m sure you’ll be happy you spent the extra $150.
I’ve got this one myself and am pretty happy with it. I picked mine up for $799 from Highland with a bunch of extras. Occasionally it goes on sale for $750 there.
