Gorilla Woodworking Glue. Any good?
Forum topic by 404 - Not Found posted 02-18-2013 10:15 PM 1648 views 0 times favorited 41 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2964 days
02-18-2013 10:15 PM
I was in my local corner shop today. Next to the fridge with the dairy produce, was a new shelf fixture with stuff like duct tape, silicon sealer and, lo and behold, a dozen bottles of Gorilla Woodworking Glue on it.
I think it was ordered by mistake and I might be able to get a good deal on it, but is it any good? Is there anything I should know about it?
41 replies so far
10376 posts in 3642 days
#1 posted 02-18-2013 10:22 PM
It doesn’t have much of a shelf life but it works well
for certain applications. For general furniture and
cabinetmaking use, I don’t like it because I find
it messy and cleanup unpleasant. It foams up
and fills gaps so it can be useful for repairing old stuff.
Waterproof too I think.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2067 days
#2 posted 02-18-2013 10:22 PM
G glue is a moisture activated polyisocyanate glue (like super glue) It is exothermic, and expands. It is a great glue for gluing loose joints, and dis-similar material together. I have not seen it react with oak, but it is messy, and IMO hard to sand and use. I only use it now to redo loose joints, because it expands to fill open cavities. it should be noted this is what I know about the original G glue (orange label, brownish glue) The company makes a wide variety of adhesives now.
-- Who is John Galt?
View HorizontalMike's profile
HorizontalMike
7755 posts in 2908 days
#3 posted 02-18-2013 10:29 PM
Wow, I know Renners asked the question, BUT I sure appreciate the detailed responses on how it operates. I first bough a bottle of GG but quickly learned about TB-III and never looked back, thoug I still have a bottle of GG sitting on the shelf. I am very familiar with CA glue, so all this make much sense to me now. THANK GUYS!
joeyinsouthaustin
#4 posted 02-18-2013 10:37 PM
It doesn’t have much of a shelf life This is because it reacts with the moisture in the air, and co’2. To extend it’s life, squeeze the bottle until all the air is out, and then cap it. It will last longer this way, but I found you only get to do this 2 or 3 times before the tip and cap get mucked up and won’t seal. Most of the places that I used it I now use a CA glue with a catalyst for instant drying. Still great for repairing old stuff. That is all, I think I am getting stuck on this topic… ;)
View Dallas's profile
Dallas
3599 posts in 2481 days
#5 posted 02-18-2013 10:37 PM
Both Loren and Joeyinsouthaustin couldn’t be more wrong.
The OP asked about wood working glue by Gorilla which is an excellent choice. It is a PVA glue just like TiteBond and in many cases works better. Plenty of strength, about a 10 minute open time.
It is also capable of being used with radio frequency curing.
It’s also cheaper for the 18oz size than TB… $5 or less per bottle. The small 8 oz bottles aren’t much of a buy @ $4.
Our local Ace Hardware got their display in and I bought every 18 oz. bottle they had for $4.59 ea.
I have had a bottle hidden on a shelf for two years that I forgot about and it worked just fine.
Please Gentlemen, learn the difference in Gorilla products.
View Hammerthumb's profile
Hammerthumb
2844 posts in 1970 days
#6 posted 02-18-2013 10:38 PM
I use the moisture cured urethane Gorilla glue for jointing boards together. I don’t recommend it for M/T joints or similar joints as the glue does foam and expand. I have found that it can make glue joints almost invisible. It is waterproof and very durable. It is also expensive. It does sand easily and takes stain. If you use it to joint a board, scrape the excess off after it cures before sanding. It scrapes rather easily.
-- Paul, Las Vegas
View DKV's profile
DKV
3940 posts in 2498 days
#7 posted 02-18-2013 11:17 PM
Renners, I agree they probably ordered Gorilla glue and received Gorilla wood glue. Try to make a deal. They probably don’t even know they have the wrong stuff.
-- This is a Troll Free zone.
404 - Not Found
#8 posted 02-18-2013 11:34 PM
It is the Gorilla Woodworking PVA that I’m talking about, not the Polyurethane one, which always seems to cure in the bottle on me.
Thanks Dallas, I will go by your recommendation. FWIW, there is not much choice in PVA glue here, any English jocks will be familiar with Evostick green or blue, but I avoid that because it reacts (leaves a stain) on oak, then there’s Hafele glue, by the gallon, and that’s about it, so I was excited to see the GWG today.
That’s quite sad isn’t it?
joeyinsouthaustin
#9 posted 02-18-2013 11:45 PM
Thanks, sorry to be heading down the wrong track,to protect my ego I did state what glue I thought I was talking about, and checked to GG website to make sure my memory was fresh. I have never used the gg pva. But this is what I can contribute. Any PVA glue has a shelf life of about 1 year, and should be protected from freezing. If it is stringy, lumpy or separated it is no good, if not even Tightbond says it will last longer. I would buy a bottle and see if your corner shop keep didn’t get a good deal on it cause it was no good, and then, since you have that much trouble getting it, buy as much as you can use in one year???
HorizontalMike
#10 posted 02-18-2013 11:49 PM
You now Dallas, if I KNEW what the heck was going on I would FIX it! Please do not bitch about those of us who want to know something WITHOUT a full correction of what the hell you are talking about! If you are going to correct me FINE! But tell what the me what the hell you ARE CORRECTING! Don’t just act smart and if the rest of the rest of the world is dumb, EXPLAIN!
Kapish!?
View NormG's profile
NormG
6109 posts in 2998 days
#11 posted 02-19-2013 12:06 AM
I like it, both coming and the white
-- Norman - I never never make a mistake, I just change the design.
Dallas
#12 posted 02-19-2013 12:18 AM
HM. Hunh? I’m not sure what twisted your panties. But I apologize whatever it was. Chill out big fella, it’s all good.
View PurpLev's profile
PurpLev
8535 posts in 3643 days
#13 posted 02-19-2013 12:37 AM
I’ve used it and it worked quite well. also used it for a cutting board that is seeing daily use for the past year or 2 and its holding up very well to the liquids , soap and water it sees daily.
on specs it is identical to TB-II
View Kreegan's profile
Kreegan
1452 posts in 2141 days
#14 posted 02-19-2013 12:50 AM
It’s my wood glue of choice. Pretty much identical to Titebond II, but a little cheaper. I like it because it’s effective down to 50* F.
HorizontalMike
#15 posted 02-19-2013 12:54 AM
Come on Dallas, what the hell? Do you NOT know how to explain gorilla Glue? I do NOT understand the difference. EXPLAIN,... and get off your high horse. Geez, this is a woodworking question already… get it?
showing 1 through 15 of 41 replies
