Why buy short clamps?
« back to Joinery forum
Forum topic by ToddJB posted 02-18-2013 08:48 PM 2123 views 0 times favorited 32 replies Add to Favorites Watch
View ToddJB's profile
7882 posts in 2067 days
02-18-2013 08:48 PM
I am getting ready to do my first joinery project and will need to really bone up on my clamps (I only have 12” irwin quick clamps mostly for construction projects). While investigating what I want I keep coming back to asking “Why would someone buy a short clamp?”
So I pose the question “Why do people buy short clamps”? A 36” F or bar clamp will clamp a 6” glue up right?
Is it just awkward to have the extra overhanging bars? My wallet doesn’t mind awkward ;)
-- I came - I sawed - I over-built
32 replies so far
View mds2's profile
310 posts in 1880 days
#1 posted 02-18-2013 08:50 PM
I have some 6” bar clamps that get used WAY more than my long clamps. Need to buy about 20 more of them.
View Dallas's profile
3599 posts in 2423 days
#2 posted 02-18-2013 08:51 PM
I like my 6” and 12” clamps.
When glueing up narrower pieces a bunch of 6” clamps 3” apart is much easier to handle than a bunch of 18”, 24”, 30” or 36” clamps.
4910 posts in 2429 days
#3 posted 02-18-2013 08:56 PM
You’ll get pretty tired handling that extra weight (and having those long bar in the way)using those larger clamps when a small one would do. My shorter ones get used far more often than the longer ones.
View JayT's profile
5555 posts in 2147 days
#4 posted 02-18-2013 09:00 PM
Awkward, yes, but also do not discount what having all that extra weight as a long lever can do when you are trying to get everything aligned on glue-up.
I’m with the others, I use the shortest clamps that I can get away with and can always use more shorties. Your wallet may not mind awkward, but mine can buy more short clamps than long ones for the same amount of money, too.
View SnowyRiver's profile
51457 posts in 3417 days
#5 posted 02-18-2013 09:02 PM
Even though long clamps will work for short items, it’s more convienient to use short clamps on small items On small items they are much easier to use. I have clamps from 12 inches to 50 inches and I can double them up to make longer ones. When making a small box for instance, I like to use small clamps because they are easier to handle and not so heavy and they dont take up a lot of room. I use a lot of Bessey Revo clamps since they clamp nice and square…nice for cabinet work, and I also use a lot of Jorgensen ISO clamps because they are great for clamping things to the bench and they work great for clamping things like mouldings etc.
-- Wayne - Plymouth MN
View Lee Barker's profile
Lee Barker
2170 posts in 2787 days
#6 posted 02-18-2013 09:04 PM
You ask a very good question!
Too-long pipe clamps stick out the backside of the assembly table or bench. No big deal. Too long bar clamps stick at you—not good.
I keep six 6” bar clamps on each side of the table. I have to take a step or two for the 18s, 24s and 35s.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View TimberFramerBob's profile
68 posts in 1860 days
#7 posted 02-18-2013 09:06 PM
was just going to post pretty much the same thing as JayT…......use the shortest clamps you can. the money you save by using all big ones is gonna be spent in time setting things up or fixing them when the heavy clamps pull it out of alignment….
-- ..........a man who works with his hands, his brains, and his an artist.
View Manitario's profile
2619 posts in 2819 days
#8 posted 02-18-2013 09:07 PM
I just bought a bunch of short clamps after struggling for the past couple of years using long clamps…makes life a lot easier when gluing up a 6” piece not to have 40” of bar overhanging…
#9 posted 02-18-2013 09:08 PM
Got it. So they can function the same way, but it’s just a hassle. This project will require the long boys, so they are the ones going to be purchased first – I guess we’ll see how annoyed iI get once I start doing smaller glue ups.
Here’s another question: I’ve read that you only need to calculate clamp pressure per inch for one face to be glued, and that it does not matter how many multiples you have after that. Is that correct?
#10 posted 02-18-2013 09:12 PM
I’ve made a lot of furniture…..youre better off getting a feel for your clamping pressure. Not sure I’ve ever calculated how many pounds per square inch of pressure a board should have on it….........if it falls apart clamp it tighter….......if all the glue comes out on the floor…..clamp it looser…..:)
View Don W's profile
Don W
18672 posts in 2504 days
#11 posted 02-18-2013 09:13 PM
If your buying bar clamps, get the pipe in 2 sections with a coupler. Then you have both.
you don’t need to calculate anything. Just clamp it tight.
-- - Collecting is an investment in the past, and the future.
#12 posted 02-18-2013 09:18 PM
Don, I’m not sure if you came up with that idea, but it’s a genius one. Thank you.
I was just sitting here thinking, “How often am I really going to need like 6 or 7 48in clamps?”
Don W
#13 posted 02-18-2013 09:20 PM
I’ve got a pile of couplers but I doubt I thought of it. But maybe in a smarter life, who knows.
View Earlextech's profile
1160 posts in 2627 days
#14 posted 02-18-2013 09:31 PM
Calculating clamp pressure? I have to ask, are you some kind of engineer? Trying hard not to be a smart ass (better than a dumb ass though) but in my experience engineers tend to overthink things and make them more complicated than they need to be. Even if you calculated how would you apply that calculation to the clamp? Am I underthinking? I’m with timberframerbob and don w, practice and experience will teach you more than a math problem in this case.
View crank49's profile
4030 posts in 2907 days
#15 posted 02-18-2013 09:39 PM
I buy short clamps so I don’t need so many long ones.
For example: building my work bench. The legs and stretchers were built up as laminations.
I needed a minimum of 6 clamps of 8” capacity each for each leg or stretcher.
I had to do two legs per night. I needed my longer clamps to built the top and I only had 6 long ones.
And yes, it is a point where the long bars sticking out get in the way or keep you from orienting something the way you might like to.
showing 1 through 15 of 32 replies
