biscuits for structural strength?
Forum topic by JesseTutt posted 02-18-2013 07:44 PM 2127 views 0 times favorited 30 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2346 days
02-18-2013 07:44 PM
Topic tags/keywords: question biscuits adding structual strength to a joint
Are woodworking biscuits intended for alignment purposes only or do they add structural strength to the joint? I have read both stories on the Internet.
30 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2605 days
#1 posted 02-18-2013 07:47 PM
I would be interested to see an actual data comparison, if anyone has one. I used to use biscuits for alignment. From what I concluded, biscuits in a long-grain to long-grain joint did not add any structural integrity, as long-grain to long-grain is going to be as strong as it gets. In situations involving end-grain, such as butt joints and miter joints, they did offer some strength.
But again, I’d like to see real data.
View ClayandNancy's profile
ClayandNancy
520 posts in 3251 days
#2 posted 02-18-2013 07:57 PM
My only reason for using biscuits is for alignment, I don’t believe they are really adding any strength to the joint, but I could be wrong.
View Loren's profile
10477 posts in 3883 days
#3 posted 02-18-2013 08:00 PM
In long glue joints they don’t add much but they can
help with aligning boards if you don’t have other
methods like cauls to do it.
Sometimes I have put little wire nails in the edge of
a board and clipped the heads off. As the clamps
are closed, the clipped off nails are pressed into
the other board and the boards won’t slip around.
Don’t try to glue end grain to end grain or end
grain to long grain without putting a reinforcement
of some kind. Biscuits work, as do dowels, nails,
screws, tenons, and so forth.
404 - Not Found
2544 posts in 3205 days
#4 posted 02-18-2013 08:13 PM
Are biscuits for alignment or do they add strength?
You will find the camp divided on this question. I personally say they add strength, and base this on the fact that when I’ve tried busting apart a piece that was biscuit jointed it has been a lot harder than a similar piece that wasn’t.
View Clint Searl's profile
Clint Searl
1533 posts in 2597 days
#5 posted 02-18-2013 08:40 PM
Alignment only; I don’t glue them in. Never had a joint fail.
117417 posts in 3813 days
#6 posted 02-18-2013 08:50 PM
I agree that on long joints there are not necessary for strength, I’ve not found of using them at all for long grain and rarely for other joinery. Yes biscuits do add strength to other types of joinery like butt joints but if you really need a strong joint I would prefer other types of joinery rather than biscuits .
View Lee Barker's profile
Lee Barker
2170 posts in 3086 days
#7 posted 02-18-2013 09:12 PM
Ok. We’re clear on the long grain to long grain issue.
As for end grain to anything else, it would depend on the joint and the stresses it will likely undergo. In general, a mortise and tenon joint with 95% glue failure will still withstand shear if there are no forces trying to remove the mortise from the tenon.
Further, if there is potential for racking, I’d put my coins on the MT.
That said, there are many applications where a biscuit joint is just the ticket, and blindingly fast.
Short answer? “It depends.” The more joints you have in your skillset, the better the project will proceed.
Kindly,
JesseTutt
#8 posted 02-18-2013 09:14 PM
Thanks all!
I went ahead and glued three biscuits into the 33 inch long board.
404 - Not Found
#9 posted 02-18-2013 09:56 PM
^ It depends…
404 - Not Found
#10 posted 02-18-2013 10:03 PM
If it’s going in a glass case and will only ever be touched by someone wearing white cotton gloves, and handled like a Faberge Egg, then biscuits would probably suffice. Just my 0.02
View TimberFramerBob's profile
TimberFramerBob
68 posts in 2159 days
#11 posted 02-18-2013 10:03 PM
LOL…..im a big fan of mortise and tenon.
-- ..........a man who works with his hands, his brains, and his heart.....is an artist.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3049 days
#12 posted 02-18-2013 10:04 PM
Biscuits add considerable strength to a glueup. In endgrain-to-long grain joints, the glue itself has very little strength. In these applications biscuits are structural. They are great for web frames in case goods.
Tabletops probably don’t need biscuits most of the time, but they are added security.
If anyone doubts the strength of a biscuit, just join two small boards without glue. Then soak them in the sink for a few minutes. I did this, and passed the boards around to see if anyone could pull the boards apart. Nobody could!
Some brands are better than others, I like the Dewalt biscuits (they fit better).
View Monte Pittman's profile
Monte Pittman
30133 posts in 2574 days
#13 posted 02-18-2013 10:12 PM
I use them. At least in my mind it’s a stronger joint.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3150 days
#14 posted 02-18-2013 10:15 PM
Jesse: ”...I went ahead and glued three biscuits into the 33 inch long board….”
Jesse, I just completed a Shaker chest that had 5ft tall legs that called for biscuits to join them to 3/4in veneer ply sides, however, not having a biscuit joiner, I chose to use a long dado to join these legs to the sides. See upper left, where leg is dado’d. Worked great and added strength. Many ways to do this…
http://lumberjocks.com/projects/78752
View ChuckC's profile
ChuckC
843 posts in 3171 days
#15 posted 02-18-2013 10:26 PM
Alignment for me. It may add a little strength but if I’m concerned about strength for a particular joint I’ll go with something other than a biscuit.
I Liked the clipped nail idea Loren mentioned!
showing 1 through 15 of 30 replies
