Why do you guys cover your shop walls with board(etc) please?
Forum topic by orchard posted 02-18-2013 08:15 AM 3268 views 0 times favorited 22 replies Add to Favorites Watch
View orchard's profile
orchard
8 posts in 1891 days
02-18-2013 08:15 AM
Evening/Morning :) As in the title really chaps, I’m as green as the hills in late spring and bought some board to stick on (what we call) breeze block garage wall before installing and attaching my kit to it. I sought advice as to the best way to achieve this in the uk, and I was told it was pointless, and that I may as well install directly.
You guys all seem to take it as a given, and debate whether to paint these false walls and what colour etc.
What’s the virtue(s) of doing this please?
Also, is there any way of minimising this forum for mobiles please, my BB keeps on bugging out :)
Thanks loads in advance
Cheers
Nick
22 replies so far
View Monte Pittman's profile
Monte Pittman
28936 posts in 2304 days
#1 posted 02-18-2013 10:24 AM
I see no point in painting shop walls. Just me.
My previous phone minimized the forum for me. New one doesn’t.
-- Mother Nature created it, I just assemble it.
orchard
#2 posted 02-18-2013 10:59 AM
Thanks Monte :)
I’m probably going to have to paint whatever surface I settle on, if only because there’s no natural light.
What I was wondering was what the reason was behind you guys tending to put a wooden or plasterboard surface over a brick/breeze block wall in your shops, and whether I should do likewise over a good wall :)
[Cheers for the mobile tip, shame, because my BB bugs out, and even when it doesn’t re-formatting sucks lol]
View helluvawreck's profile
helluvawreck
30765 posts in 2833 days
#3 posted 02-18-2013 11:16 AM
I prefer plywood or OSB on the walls because you can hang things on it where you want without any hassle. I can do without the paint. However, white paint does reflect light very well , tends to brighten the atmosphere, and you can more easily see tools on the wall.
helluvawreck aka Charles
View knotscott's profile
knotscott
7980 posts in 3342 days
#4 posted 02-18-2013 11:21 AM
Putting drywall or paneling over it allows you to add some insulation, plus some folks prefer the finished look.
White paint will brighten up the space.
View REL's profile
REL
76 posts in 3623 days
#5 posted 02-18-2013 11:25 AM
I kinda like clean new cement blocks unpainted. Ours are usually a medium gray. Painting white brightens things up for artificial lighting, but is it really necessary? I would prefer more lighting; even more than necessary to brighten the shop up. This will result in less work and upkeep.
To answer your question, The answer is no! Wall board or wood siding is not necessary and adds nothing to the workings of a woodworking shop.
If you must paint, god bless you, pick the color and type of paint you want.
-- REL, North Jersey
helluvawreck
#6 posted 02-18-2013 11:29 AM
Insulation saves on the heating bill if you heat your shop. However, a shop is a very personal place and you should do whatever makes you happy and enjoy your time in the shop to the fullest.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2238 days
#7 posted 02-18-2013 12:05 PM
Nick,
Welcome to LumberJocks , a world of advise, opinions, and experiences, all shared without judgement.
To your point, Finished vs. Unfinished concrete block walls in the shop.
You can indeed leave the surface bare if insulating isn’t necessary and you can use French Cleats to attach cabinets, tool racks and pegboard storage to the walls with no problem or just use stand alone fixtures/cabinets.
Work Safely and have Fun. – Grandpa Len.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
Smitty_Cabinetshop
15280 posts in 2584 days
#8 posted 02-18-2013 12:26 PM
Personally, I’m in the ‘paint concrete walls’ camp because gray concrete, to me, is beyond industrial and is depressing. Absorbs light, looks dank, is cold, etc. etc. And it absorbs moisture. So I’d seal it and paint it before installing a french cleat system. Why that? A few well-place anchors are better than holes all over the place in cement block. My .02
orchard
#9 posted 02-18-2013 12:27 PM
Some fantastic responses thanks!
Unfortunately it’s muddied the waters, haha :)
I’ve bought the OSB for one of the two walls, so cost isn’t an issue, but with it being a single garage maybe I’d regret eating into the width…oh decisions…insulation isn’t an issue though, but I will need to attach my RAS/feed/extraction and probably storage etc…
What are French Cleats please? Are they what we call Rawl/Wall Plugs?
Smitty_Cabinetshop
#10 posted 02-18-2013 12:37 PM
orchard
#11 posted 02-18-2013 12:47 PM
French Cleats are a good idea in the shop—well versatile and give a nice ordered feel :)
orchard
#12 posted 02-18-2013 01:15 PM
Crikey Scotsman, you could build a longboat in that badger :o
View johnstoneb's profile (online now)
johnstoneb
2869 posts in 2139 days
#13 posted 02-18-2013 01:45 PM
That type of block leaks air badly. If you are going to heat your shop space you will need to seal the block with some kind of paint.
-- Bruce, Boise, ID
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#14 posted 02-18-2013 01:52 PM
I think the main reason to insulate and heat. The stud walls also give you a place to run the electrical wiring. In my shop I used sheet rock on the inside and painted it white for brightness as I have only one small window.
-- Bondo Gaposis
View HorizontalMike's profile
HorizontalMike
7749 posts in 2880 days
#15 posted 02-18-2013 02:04 PM
Referencing @knotscott’s image in post #4, I would go that route, BUT instead of drywall you might consider 3/4in plywood as a final surface. Yes this adds quite a bit to the cost factor, however, with a 3/4in ply wall you will be able to attach/hang anything anywhere you choose to do so. And going this route does allow you to hide all wiring for those multiple power outlets that you will need to install anyway. And painting the ply white is not a bad idea either.
My 2-cents…
