Reliant Jointer Question
Forum topic by fredf posted 76 days ago 178 views 0 times favorited 6 replies Add to Favorites
View fredf's profile
fredf
228 posts in 246 days
76 days ago
Topic tags/keywords: reliant jointer question bed fence
I am going to go look at a reliant jointer tomorrow, asside from making sure the beds and fence are flat, what should I look for?? or should I just run the other way? I figure for $100 I can’t to too far wrong . . .
-- Fred, Springfield, Ma
View juniorjock's profile (online now)
juniorjock
358 posts in 302 days
76 days ago
You’re right, for $100. I think I’d just check to see if all the adjustments work smooth. Check the knives. A new set may cost you more that what the jointer is worth. Good luck
-JJ
-- Make things with wood.
View brianinpa's profile
brianinpa
941 posts in 259 days
75 days ago
I run towards these types of bargins! Check the cutting head bearings and don’t forget the motor. If the motor is filled with wood chips, it may be an indication of how well the previous owner cared for it.
View cmaeda's profile
cmaeda
99 posts in 91 days
75 days ago
Most of my large tools are used from Craigslist. Keep in mind that most tools being sold are in bad shape so plan on spending a lot of time restoring the jointer.
A lot of stuff is pretty inexpensive to repair but there are a few deal breakers.
Look at all the cast iron surfaces and check for cracks. If I see cracks, I won’t buy.
Make sure the bed and fence are flat.
Make sure the motor works. Motors are pretty easy to repair but some repairs take a really long time so unless its’ a really good deal, stay away from broken motors.
Most bearings are pretty inexpensive to replace but make sure the problem is with the bearing and not the arbor or the knife holder.
Before looking at the jointer, its’ also helpful if you can get an exact model number to see if you can still get replacement parts and see how much common stuff like the belt and the knives cost.
I think that’s about it.
View carlosponti's profile
carlosponti
9 posts in 83 days
74 days ago
I bought a used jointer from a co-worker it ran fine. like already mentioned make sure the cast iron isnt cracked or warped on the fence and not cracked on the bed. make sure you can get it adjusted etc. dont be fooled by rust on the top that can be cleaned up. mine was rusted took some care and its smooth again.
-- Got Wood?
fredf
74 days ago
I picked it up last night, not bad condition at all. the Power switch was so full of sawDUST that you couldnt push it so it ran all the time, It needed a new power plug (ground pin was missing) those issues are now fixed, and the top has been cleaned well enough to use. The worst problem is that the knives were MISSING (considering the DUST in the switch they must have been really dull,) the guy did had the wedges with the gib screws so for $18 or so for new blades we will be in business. At some point I will probably want to replace the belt with a link belt, but that can wait till I am gainfully employed again. built in 1992, its sweet 16 :-)
cmaeda
99 posts in 91 days
73 days ago
If you’re buying new blades consider an upgrade to carbide blades. You can joint ten times the amount of wood between sharpenings. Just don’t use it when you’re jointing rough lumber, as sometimes, you’ll get nails or other random metals bits in there.
Bookmark And Share This Page
