Help needed with a jointer refurbish
Forum topic by Drew - Rock-n H Woodshop posted 02-18-2013 12:27 AM 1756 views 0 times favorited 10 replies Add to Favorites Watch
View Drew - Rock-n H Woodshop's profile
644 posts in 2660 days
02-18-2013 12:27 AM
I have a Delta rockwell 6 1/2 inch jointer that was given to me free from my brother. I was lucky enough to find an online owners manual for the model, but I do not have a guidance to take it apart. The jointer beds sag from one end to the other and apex at the knives. I have tried adjusting the gibs, But I do not know the proper method. Is there anybody with this jointer that has Experience taking it apart, refurbishing it and putting it back together? The model number is 37-220
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
10 replies so far
Beginningwoodworker
13345 posts in 3642 days
#1 posted 02-18-2013 12:51 AM
Thats so cool Drew, try to search for a manual online.
View DouginVa's profile
DouginVa
490 posts in 2242 days
#2 posted 02-18-2013 01:47 AM
Try this Fine Woodworking article:
http://www.finewoodworking.com/tool-guide/article/jointer-tune-up.aspx
It doesn’t necassarily show you how to break down a jointer but it walks you through making the beds co-planar. There is also a FWW article on how to replace the cutter head with the new helical cutter heads. I don’t know for sure if that article is on-line or not. And you may need to be a member of their on-line site to access these too.
The WoodWhisperer also has a vid on making your tables co-planar.
-- Just a man with his chisel.........
View lew's profile
lew
12019 posts in 3725 days
#3 posted 02-18-2013 02:21 AM
It may be that the gibs do not add enough elevation to the ends of the table. You might have to get some shim stock and place it on the ways to get the height you need.
View JustJoe's profile
JustJoe
1554 posts in 2008 days
#4 posted 02-18-2013 02:31 AM
If it’s really vintage then lew probably nailed the problem – you’ll need to add some shims. There is a user maintenance manual on owwm that might have a decent diagram:
http://vintagemachinery.org/pubs/detail.aspx?id=1551
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
#5 posted 02-18-2013 03:46 AM
Where is a good place to get shim stock???
Beginningwoodworker
#6 posted 02-18-2013 04:15 AM
Old soda cans will work as shim stock.
View nwbusa's profile
nwbusa
1021 posts in 2255 days
#7 posted 02-18-2013 07:58 AM
I used to have a 37-220. Solid little machine. How far out of level are the tables?
-- John, BC, Canada
nwbusa
#8 posted 02-18-2013 07:59 AM
Double post
-- John, BC, Canada
View lew's profile
lew
#9 posted 02-20-2013 05:16 PM
Shim stock is available at Amazon and Fastenal, however, it’s not cheap. Use a feeler gauge to determine what thickness is required and then go to a machine shop- they might just sell you a small piece.
View chrisstef's profile
chrisstef
17312 posts in 2976 days
#10 posted 02-20-2013 06:08 PM
37-220 owner here as well. I think Lew’s got the answer in shimming the ways. Those gibs screws in the back should be adjusted from the inside (cutter head) out. I dont think that there is any way your are “supposed” to do it. i just fiddled with them until i got it about right. Id go with the soda can method for shims personally.
I used the wood whisperer’s site opened up on my iphone to help in getting it tuned up. It did take a few hours i must say.
