TS dust collection
Forum topic by toolie posted 02-17-2013 08:26 PM 1172 views 0 times favorited 6 replies Add to Favorites Watch
View toolie's profile
toolie
2123 posts in 2629 days
02-17-2013 08:26 PM
for a while, i’ve had to attach a flex hose from the nearest blast gate to each of my table saws. this meant reaching under the respective TS in some way to fix the quick connect flex hose fitting to the receptacle on the tool. and that’s become a pain to do due to the reach needed to get to the saw receptacle.
this weekend, i got tired of reaching and looked around at what scraps and left over parts i had from other projects and came up with these two solutions:
View History's profile
History
399 posts in 1982 days
#1 posted 02-17-2013 08:35 PM
In your first picture it looks like your useing one of those inefficient generic flat shallow trayed plastic dust hoods. They are garbage in my opinion, plus you either have a kink in the hose or a sharp bend in it, not good. The second one looks much better with what looks to me like a modified Craftsman hood that is piped out a little better, but I would still try to do without the elbows, or atleast get rid of one elbow. Just my opinion.
View kdc68's profile
kdc68
2657 posts in 2277 days
#2 posted 02-17-2013 11:28 PM
Looks like you did a good job filling in all the openings in the back of the saw in the second photo. Great use of the scraps you had laying around you shop
-- Measure "at least" twice and cut once
History
#3 posted 02-18-2013 01:00 AM
Actually you don’t need to seal up the back that tight if you seal everything else up. Then you don’t have to worry about remembering to remove anything from the back of the saw that might bind it up and throw everything out of alignment, or worse case senario, crack a trunion.
toolie
#4 posted 02-18-2013 11:55 PM
thanks, kdc68. comments appreciated.
View pmayer's profile
pmayer
1028 posts in 3066 days
#5 posted 02-19-2013 03:28 AM
I like this a lot. Your second configuration is one of the better jobs that I have seen of corralling dust on a contractor saw. I like the hard piping and the use of two 45 degree elbows to gently make the bend.
Nice work, Toolie.
toolie
#6 posted 02-19-2013 04:21 AM
thanks. FTR, the first pic, which appears to show a kink in the flex tubing, is an optical effect. it’s a very smooth curve from vertical to horizontal.
